hi,
for the lif of me i cannot get my front bearing dust caps off!!!! any help? mike
1987 Carrera 911 2000 Getta VR6 1980 924 turbo gt clone 1980 924 turbo |
some carefull finessing with hammer. lightly tap around the circumference of the cap in an outward motion. should eventually come loose enough to pry off.
David. 85 carrera euro |
sharp cold chisel works well
These threads come up frequently. Since it's here again, what years had the cap that fit outside the hub center? My '71 has these and I prefer them to the later ones that fit inside the hub center.
I assume that's the ones he is asking about. Some use a muffler clamp in the groove and pry against that. Some buy turbo caps and use the bolt in them to remove. Mine come off in a breeze with a small pry bar carefully placed on the inner edge at a couple of places around the circumference and walk it off. Much simpler. |
RETIRED
Big ******* Channel lock pliers....grip top and bottom, rock em off....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
I clamped on a 2" exhaust clamp and then pried on that with a full size crowbar. They came off pretty easy.
85' 911 Coupe sw chip, ghl sport cat, M&K sport muffler, short shift, magnecor wires, heat sheets, cool collar, Momo anatomic leather shift knob... |
thank god, finally, I read through the archives and found a two hammer way of getting them off.
wow!! that was difficult!!!! thanks guys mike
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
I used big Vice Grip designed to fit around round objects like exhaust pipes (the area between the clamps is round/open when in closed position). Put a shop rag or two on the cap to avoid excessive scratching, and lock on tight. Clamp on with the tool pointing into the wheel, not parallel with it.
I used a combination of rocking by hand and hitting the handle of the tool with a hammer/rubber mallet. Reposition the tool one quarter around the cap after a few rocks/hits. You'll start to see new metal shortly, but keep on rotating. I put some anti-sieze on them before reinsertion to ease removal next time. Cheers!
Dan '87 911 Carrera - Cabriolet |
The claw hammer method worked for me only I didn't use the muffler clamps. Tap the hammer head with another hammer, the area between the claw and head acts as a fulcrum, and work around the hub one tap at a time. Don't tap the threads or you'll be sorry.
'80 SC |
I had to use a lot of hate to get them off my '76. Yeah, it was pretty much hate and angst that got them off. Like when you stand up and bang your head on an open cabinet door. Take that reaction and aim toward the cap with a chisel and hammer. I destroyed both of mine getting them off and installed new ones.
Remember our friends: Warren, Ron, Grady, and Steve. 76 912E RS (i.e. "Real Slow"); 63 Volvo P1800 "S"; 71 Jaguar XJ6 Series 1; 05 GT3; 23 Cayman GTS 4.0; 97 Boxster |
since mine are comming off again I was wondering if anyone has just welded a bead on two sides to pry against?
I'm starting to notice that if I take mine off more than a couple times more there's going to be some serious pits and gouges in them. |
Jeez....are we simply ignoring and bypassing *this* ..???
It is by far the easiest, least painful solution yet...as I posted before here.... http://forums.pelicanparts.com/show...ing+cap+removal Wil
Yes, but I want a ZERO cost for a fix without having to go to the store, or having to buying new caps. Clamps didn't work for me
link didn't either (firefox) |
MBruns for President
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
Cardone really nailed it (above). Perfect description of the rage required to work on a 911 sometimes. Bravo !
guys and gals,
thanks a million for your help!! all done!! Mike
The exhaust clamp works great and only costs about $1.
Senior Member
Plastic explosives.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
Irrationally exuberant
Piece of 2x4 and a hammer, gentle taps around and around using the 2x4 like a punch. Comes right off, no hate, no hammer hitting the wheel studs and cost $0.
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
