strother's Avatar
Question Advice needed to fix SC turn signals
Well, my turn signals failed tonight. Worked at the beginning of the drive, then stopped. I haven't checked the fuses yet (I promise to first thing in the morning). Assuming that it's not the fuses, how can I know if it is a relay or switch problem?
Old 01-09-2005, 08:46 PM
Send a message via AIM to fintstone
If it is the flasher (relay)...generally the emergency flashers also do not work.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 01-09-2005, 11:11 PM
