Virginia Rocks!
VaSteve's Avatar
Pinion Bearing Nut Torque
Is there a specific torque spec for the pinion bearing nuts? I'm guessing if so, it was a low number since they came out pretty readily. I can't find anything in 101 Projects or Bentley.
Thanks.
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na
Guards Red is for the Unoriginal
Old 01-03-2005, 07:01 PM
AFJuvat's Avatar
Not quite sure which nut you are talking about, but here are the values for "pinion\shaft nuts"
Drive Shaft (collared nut) M30X1.5: 230NM
Drive Shaft (castled nut) M18X1.5: 160NM
Drive Pinion (collared nut) M24X1.5: 250NM
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 01-03-2005, 07:13 PM
Virginia Rocks!
VaSteve's Avatar
It's not really a nut (i need to stop working on this at night) it's a hex head bolt as seen here in Wayne's photo:
Old 01-03-2005, 07:16 PM
AFJuvat's Avatar
Ahhhhh
the pilot bearing screws!
10 NM
AFJuvat
Old 01-03-2005, 07:24 PM
Virginia Rocks!
VaSteve's Avatar
Wow. That seems low. But like I said it was easy to take off.
Thanks for the answers on both threads this evening.
Old 01-03-2005, 07:27 PM
