Slumlord
Porsche_monkey's Avatar
Speed Sensor Removal
The speed transmitter in my 84 seems to have quit.
I've removed the bolt and spring retainer, but the sensor is seized solid in the transmission. Any tips on how I might remove it?
Old 08-30-2006, 12:59 PM
Oh Haha's Avatar
Use a dentists pick or even a small knife. You just need to pry it out of the "hole".
Pacific Blue
Wayne
Old 08-30-2006, 01:57 PM
Slumlord
I got the innards out with a screwdriver, the outerbody is still in the hole.
Is it exposed to oil on the backside? If so, I shouldn't remove it until I get my new one...
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 08-30-2006, 02:00 PM
Oh Haha's Avatar
Nope, no oil.
It's a magnet -type device. You'll see once you take it out.
Pacific Blue
Wayne
Old 08-30-2006, 02:02 PM
Oh Haha's Avatar
Then only part that comes out is the the piece with the wire attached. Was yours physically broken?
Pacific Blue
Wayne
Old 08-30-2006, 02:03 PM
Slumlord
I think my switch seperated ....I guess i'll know better when I get my new one. The outer shell is still in the tranny.
Old 08-31-2006, 07:45 AM
Oh Haha's Avatar
Yikes, that's ugly. You should be able to get the outer shell out, though. I believe you could just dig/scrape the remaining plastic out and then clean it and be on your way.
Pacific Blue
Wayne
Old 08-31-2006, 12:08 PM
Driving member
jester911's Avatar
Out of curiousity, what are the symptoms of a non-working speed sensor?
Jerry
'86 coupe gone but not forgotten
Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason.
Old 08-31-2006, 01:18 PM
Slumlord
No speedometer, no odometer.
Typical failure mode is the gear failure in the odometer (I had that also) which leaves you with a functional speedometer, but no odomter.
If the switch has failed you lose the pulse train to the speedo & odometer so neither one works.
Old 09-01-2006, 08:20 AM
Slumlord
Yes, it's so destroyed I can't even confirm what exactly caused the failure.
I'll try to dig/scrape away at the remainder in the car. If that fails I'll pull the engine over the winter and address some tranny and oil issues at the same time.
Old 09-01-2006, 08:22 AM
just tap a small screwdriver under the edge and pry it out. it's just plastic.
206 637 4071
Old 09-01-2006, 08:41 AM
Slumlord
Thanks John, I've been reluctant to use the necessary force, but I'm headed in that direction.
84 Cab - sold!
Old 09-01-2006, 08:42 AM
