Send a message via AIM to NoLift911
Portable Compressor Setup for air tools
What do you guys do with a portable compressor setup an air tools. I need to setup a filter and a lubricator for my tools but not sure I want them just installed inline draggin around with the hose.
Has anybody setup any brackets for mounting on the compressor itself to support these? Don't really want to install a wall setup and no room with a lift.
Any ideas?
-Jeff
Jeff
Old 01-05-2005, 08:28 AM
Hmmm, hard for me to explain but I used a threaded brass pipe off the compressor outlet and right to the filter assembly. The pipe supports the assembly. The quick connect is hooked right up to the filter outlet.
I don't have an inline lubricator because I also sandblasted and sprayed with the same set-up. I'd oil manually. With the extra weight of the lubricator you may need to fab up a smal bracket.
Warren & Ron, may you rest in Peace.
Old 01-05-2005, 08:36 AM
Heck, I’m only 5 not 71!
targa80's Avatar
I agree with Rick's comments, on my prortable compressor I installed a short pipe to a water filter with an quick disconnect the other end. I manually lubricate the air tools with a few drops of oil before use. Unfortunately, I found that the portable compressor (20 Gal) was inadequate for most air tool applicationsin my garage. I ended up purchasing a 7HP 60 gal single stage compressor that will run everything. The portable unit is only used rarely now.
Pat Henry
Targa80
1980SC Targa (Mocha Brown)
Old 01-05-2005, 08:49 AM
Friend of Warren
I do what Rick and Pat do.
Kurt V
Old 01-05-2005, 09:00 AM
scottb's Avatar
How about something like this mounted to the frame of the portable compressor. A short pipe or hose would be all that would be needed between the compressor and the filter, and then a quick disconnect on the filter output. Seems easy enough...
1984 Targa
Old 01-05-2005, 02:16 PM
B D B D is offline
B D's Avatar
The price is right, for a weekend mechanic is the quality of this unit sufficient?
68 911L
Old 01-05-2005, 02:25 PM
Kool and the gang....
For $22...I'll risk it - I ordered it up.
Thanks,
-Jeff
Jeff
Old 01-05-2005, 02:32 PM
