| Moderator |
				~for GeorgeK, 901Shop dual m/c~
			Dual master  setup can be used w/ stock or custom gas       Prepped for an install, weld up old m/c hole, modify 1 bolt hole in pan   The other side of the firewall  Can be used w/ stock res & lines or a Tilton as shown here
				__________________ Bill Verburg '76 Carrera 3.6RS(nee C3/hotrod), '95 993RS/CS(clone) | Pelican Home |Rennlist Wheels |Rennlist Brakes | | ||
|  12-31-2004, 11:14 AM |
| Moderator |
			Hey George, did you ever see this?
|  01-06-2005, 11:31 AM |
| Registered Join Date: Jun 2000
			Hi Bill, THANKS A LOT! I did not see this on the first issue, as I was at work (on call, night shift, what do people skiing -and crashing- at midnight??). Looks interesting | ||
|  01-06-2005, 11:46 AM |
| Registered |
			That looks very similar to what I have in my car.  I ended up having to hack-saw off a piece on the adjustment bar behind the gas pedal (just where the red adjuster cable ends) in order to have enough clearance for the adjuster to move.  I forgot the specifics and can't get to that part of the car right now to check.
				__________________ John '69 911E "It's a poor craftsman who blames their tools" -- Unknown "Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman Last edited by jluetjen; 01-06-2005 at 12:42 PM.. | ||
|  01-06-2005, 12:39 PM |
| Registered Join Date: Nov 2004 Location: Florida, near Daytona Speedway!
			where did you get that throttle cable? that looks very cool!
				__________________ Joe 996 GT3 RSR | ||
|  01-06-2005, 05:25 PM |
| Moderator |
			Yes, not many will notice that, it is a very nice little option.  You can use the stock or that one to eliminate any chance of the throttle hanging up.
				__________________ Bill Verburg '76 Carrera 3.6RS(nee C3/hotrod), '95 993RS/CS(clone) | Pelican Home |Rennlist Wheels |Rennlist Brakes | Last edited by Bill Verburg; 01-07-2005 at 01:36 PM.. | ||
|  01-07-2005, 01:32 PM |
