911 Door speakers
What would be a good midprice speaker that will fit in original hole with original (or plain) cover....not wanting to get into high $ stereo, which my old ears can't hear that well anyway.
PCA and BMWCCA member for many years 09 Boxster Base PDK (No spare tire) ![]() 05 M/B CLK 500 AMG (Spare tire) ![]() 07 BMW 530xiT (Spare tire)
MQ Quart makes a 5.25" speaker that fit in my front doors just fine, with the stock grill. Pretty moderately priced as I recall.
1984 Targa |
Recreational User
MB Quart.
I think I paid about $400 installed price for the mid level MB Quart door Speakers. The higher end were about $600 but the mid level was fine for me. It's hard to distinguish the nuances of the two with my Targa's wind noise and a Dansk dual out behind me.
I think I paid about $100 for mine, and I installed them myself in less than an hour using the factory wiring and grills.
1984 Targa |
Original Owner
Holy tomoly!!!! $400- $600
My doors are Madisound 6102-4 6.5" Polypropylene Woofers. @ $52.50 for 2. The rear are Eclipse 4X6 coax and the Targa bar tweeters are Audax. Door speakers take an hour to install maybe - on three or more beers!!
tsuter 78 911SC Turbo Targa Thaaaats Right!! |
I can tell you my install would have taken considerably more than an hour. |
In the shop at Pelican
I've got Infiniti Reference 6 1/2 components in my doors. Paid around $150 for them. Great speakers..
What about the rears using the standard grills?
Jim |
Yeah... the price seems high. You can get very good speakers from most of the major companies for between $150-$250/pair.
The main point is to buy fairly recent speaker models. Speaker technology (and the materials) has improved greatly over the past few years. (I have Pioneers in my Yarga) -MAS
77 911S Targa (current car) 87 924S (my previous car) |
1984 Targa |
Mid-level may not be the same models, so maybe you didn't get screwed. The law of diminishing returns does apply to HiFi tho.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
1984 Targa |
any chance I could see a pic of six and a halfs in the rear with stock grills?
1984 Targa |
Hey its not only diminishing returns for hi fi, my old ears ain't doin' so well either...too many nights in the disco's in the 70's/80's
Not much to see...the speakers and grills fit using the existing mounting holes. End of story.
just asked if you had a pic dude, that's all. |
Take a look at your current installation. If your current setup is held in place by only three or four screws, additional drilling will be required to install MB Quart speakers. The sheet metal drills very easily so it's no big deal. I'd like to say I took mine apart so you can see the installation, but it just happened that I'm working on my door panel and speakers today. With 1/2" of ice on the ground, I'm stuck at home.
In this photo, you can see that the speaker frame is secured through the door panel to the sheet metal by three screws. You can also see the crossover circuit inside the door. It was only secured by a couple pieces of sticky tape on the back so needless to say when I took my speaker off, the CO circuit was loose sitting on the bottom. I'm building a better bracket and will re-attach it to door. You can't use your old CO circuit and must use the ones that come with the MB Quart Speakers, so you'll have to install this also. I took a second photo to show the speaker itself which attaches through the frame with four more screws. Because of the length of the screws, they also go into the door sheet metal. My speaker is just set in place for this photo since I'm still mounting my CO circuitry back in place. After the speaker is installed, the MB Quart grill pushes into place around the speaker and fits over the speaker inside the frame. To remove it, you need to insert a thin punch or screwdriver and carefully pry it out. At least for my 79SC, this design is totally different from my stock installation.
I put Alpine Speakers all around, used the original grill in the back.
1987 Porsche 911 Carrera Targa 2006 Ford GT-Tungsten 2017 BMW M240i 1965 Porsche 912 2018 Mercedes AMG GLE 43 |
Rick Bay Area, California 1984 911 Carrera Targa 1973 VW Beetle |
