kilodawg's Avatar
Shifting question?
Have an 84 with 97K, had the shifter bushings replaced a few weeks back and have put on maybe 250 miles since then. The shifting is vastly improved but just the other day I noticed that upon initial startup (cold) I get a grind if I try to put it directly into first. No problem with any other gear and no issue after that.
Do I lose sleep over it?
TIA,
Ralph
'73 914 2.0, '74 911 Coupe, '74 911 Targa
'78 924, '84 944, '86 944 Turbo, '84 911 Coupe
'84 944 (current), '96 993 Coupe (current)
'73 911T Coupe (current)
'88 930S M505 (current)
Old 01-05-2005, 06:00 PM
randywebb's Avatar
No, just start saving up for a trans. rebuild in a few years.
Try putting it in 2nd before going into 1st.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 01-05-2005, 06:20 PM
Clutch adjust, and/or adjust the pinch fitting on the shifter splines (under the four bolt cover on the tunnel in front of the back seats).
'80 SC
Old 01-05-2005, 07:53 PM
As Randy said, put it into 2nd before going into first. That should help some.
Old 01-05-2005, 07:59 PM
djmcmath's Avatar
The graunch is because your first gear synchro isn't doing it's job quite like it used to. That noise is caused by the teeth on the slider (aka operating sleeve) catching the teeth on the synchro hub before they reach the same speed. Each time it graunches, you shave a tiny bit off the tip of a few of those teeth. When the teeth run out, the synchro won't hold the transmission together in that gear anymore, and so you won't be able to drive with that gear.
Go easy on first, and it could last a long time.
Dan
'86 911 (RIP March '05)
'17 Subaru CrossTrek
'99 911 (Adopt an unloved 996 from your local shelter today!)
Old 01-05-2005, 09:19 PM
