~for GeorgeK, 901Shop dual m/c~
Dual master setup can be used w/ stock or custom gas
Prepped for an install, weld up old m/c hole, modify 1 bolt hole in pan The other side of the firewall ![]() Can be used w/ stock res & lines or a Tilton as shown here
Hey George, did you ever see this?
Hi Bill,
THANKS A LOT! I did not see this on the first issue, as I was at work (on call, night shift, what do people skiing -and crashing- at midnight??). Looks interesting |
That looks very similar to what I have in my car. I ended up having to hack-saw off a piece on the adjustment bar behind the gas pedal (just where the red adjuster cable ends) in order to have enough clearance for the adjuster to move. I forgot the specifics and can't get to that part of the car right now to check.
John '69 911E "It's a poor craftsman who blames their tools" -- Unknown "Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman Last edited by jluetjen; 01-06-2005 at 01:42 PM.. |
where did you get that throttle cable? that looks very cool!
Joe 996 GT3 RSR |
Yes, not many will notice that, it is a very nice little option. You can use the stock or that one to eliminate any chance of the throttle hanging up.
Bill Verburg '76 Carrera 3.6RS(nee C3/hotrod), '95 993RS/CS(clone) | Pelican Home |Rennlist Wheels |Rennlist Brakes | Last edited by Bill Verburg; 01-07-2005 at 02:36 PM.. |
