Nine9six's Avatar
Question of leakdown
Gentlemen,
I am considering an 87 911 with the 3.2L motor, with 75K miles. What would be considered good leakdown #'s during the PPI?
Thanks again for the sharing of your knowledge.
Paul
If it flows, it goes. If its smooth, it moves. Any questions?
96 993 C2 (Current)
87 911 Factory Turbo-Look Cab (Sold)
85 911 Factory Turbo-Look Targa (Gone)
Old 01-10-2005, 04:51 PM
plymouthcolt's Avatar
Fom 1 to 8 or 9 is ok. Stay away from anything 10+.
Basically the lower the better. You also want to have no more than 10% variation between the numbers, if you do, again walk away.
Old 01-13-2005, 01:37 PM
Re: Question of leakdown
plenty of info in "search". It's more complicated on our cars than Detroit iron imo.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 01-13-2005, 02:33 PM
Nine9six's Avatar
Am I correct in assuming that in Plymouthcolt's response, the numbers are expressed in percentages?
96 993 C2 (Current)
Old 01-13-2005, 04:07 PM
Yes. That's the only way I've seen them expressed.
-Steve
'87 Carrera Targa
Old 01-13-2005, 04:38 PM
Hey Paul.
Don't start a new "subject" on the same, pretty please.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 01-13-2005, 04:51 PM
Nine9six's Avatar
Hey RoninLB,
I didnt...I merely requested clarification. Hopefully this meets with your approval.
96 993 C2 (Current)
Old 01-14-2005, 12:28 PM
Hey RoninLB,
just trying to give you a heads-up. Sometimes it becomes difficult banging back and forth between 2 similar subjects for the same guy. I've seen it happen a few times when the replies exceed 5 on each. By that time there's 2or3 guys jumping on you.
When I suggested search it was because there was many various comments concerning piston to barrel design, top ring vs bottom ring, etc. More info for you than what I could have provided..
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 01-14-2005, 01:26 PM
Nine9six's Avatar
RoninLB,
Thanks for your clarification!
Have a great weekend,
Paul
96 993 C2 (Current)
Old 01-14-2005, 01:40 PM
