-   -   Engine swap (http://forums.pelicanparts.com/porsche-911-technical-forum/200907-engine-swap.html)
limble 01-10-2005 06:30 PM
Engine swap
Question from T member:
Putting an 88 3.2L (911 SC) w/ Motronic EMS into a 70T.
The engine has the 88 tachometer. Should or can I use the old tach with this swap or do I have to use the new one?
What else needs to be considered? He likes the style of the older dial faces. Any possibility of a dial face swap?
randywebb 01-10-2005 10:02 PM
An msd will trigger a '73.5 tach w/o problem. I don't think anyone knows for sure for your year; also, you need to specify how you will drive it.
Search and you will find out "all we know so far" on this topic. Post your results for the next guy.
