coloradoporsche's Avatar
match tire circumferene front to back?
Hello,
I am wondering how important it is to match the tire circumference from front to back wheels. My stock tires (205/55 and 225/50) are almost exact. But I'm considering various combinations that might be off by, say, 9mm in sidewall, resulting in a different height and circumference.
Does it matter if the front matches the back?
Thanks!
Old 01-16-2005, 11:29 AM
Administrator
Jack Olsen's Avatar
It really doesn't matter very much at all, except maybe visiually. What's more important is the overall diameter of the tires you choose, especially on the rear. This will effect your car's overall gearing, as well as your speedometer/odometer accuracy.
A big disparity will change the rake (leaning forward or back) of the car.
Old 01-16-2005, 12:08 PM
I generally like tires that are the same diameter front to rear. Try using this formula and you can figure out the diameter of any size tire.
DIAMETER = (width)(aspect ratio)(2) divded by 25.4 (+ wheel size)
for 205/55/15's it would be;
(205)(.55)(2) divided by 25.4 +15 = 23.878".
This can come in handy when mixing and trying to match up different tires. On an early 911 I like to try and get around 25".
Tom
Old 01-16-2005, 12:54 PM
Administrator
Jack Olsen's Avatar
Or if that much math makes for a bad humming sound in your skull, use an online tire size calculator.
Old 01-16-2005, 01:36 PM
Noel's Avatar
BTW, you don't mention what kind of car you have. If it is a two wheel drive car, different diameter tires are not a huge deal. However, if it is a C4 (964 or 993), then you may need the same diameter front and rear as it may damage the all-wheel drive.
Gone but not forgotten -
1980 Porsche 911SC w/ -22mm/28mm Torsion Bars | Custom Valved Bilsteins | 22mm/21mm Carrera Sway Bars | Elephant Poly/Bronze Bushings | Carrera Brakes | AJ-USA Brake Cooling | Carrera Oil Cooler w/ Fan | Elephant Strut Brace | Oh, and no ABS or PSM or A/C
Old 01-16-2005, 05:10 PM
Thanks for the info, guys. I have a 79SC. I really appreciate the feedback.
Martin
Sheena is a punk rocker
Suzy Is A Headbanger
Heidi Is A Headcase
Judy Is A Punk
The Ramones' earliest titles included 'I Don't Wanna Walk Around with You,' 'I Don't Wanna Go Down to the Basement,' and 'I Don't Wanna Get Involved with You.' Dee Dee later said, "We didn't write a positive song until 'Now I Wanna Sniff Some Glue'."
Old 01-16-2005, 06:02 PM
