-   -   How does my Goetze oil rings (with the spring inside), slide onto the piston? (http://forums.pelicanparts.com/porsche-911-technical-forum/201102-how-does-my-goetze-oil-rings-spring-inside-slide-onto-piston.html)
H.G.P. 01-11-2005 07:15 PM
I have Goetze rings,
1. Does the oil spring expand with the oil ring when it's being installed? (I can't see a "break" in this spring like the other rings)
2. Does the spring "roll" down with the oil ring?
I don't quite see how this oil ring with inside spring installs?
CBRacerX 01-11-2005 07:26 PM
Spring does have a "break", and there is a wire inside. Just find the break, spread apart and install _with_ the ring proper.
Hint: Install so that the break in the spring and the ring gap are 180 degrees apart.
Chris
H.G.P. 01-11-2005 08:41 PM
Chris
I see it, thanks! Wow is that small.
kstylianos 01-11-2005 08:44 PM
You can also take the 'spring' out, place it in the land, then place the ring on top. Make sure the spring and rings gaps are not alligned.
I knew these rings would come in handy one day.....
http://forums.pelicanparts.com/uploa...1105508606.jpg
http://forums.pelicanparts.com/uploa...1105508619.jpg
CBRacerX 01-12-2005 09:02 AM
I think the last engine I did I used the method that Charlie described. Just don't spread those rings too far apart!
