LinkBack | Thread Tools | Rate Thread |
How does my Goetze oil rings (with the spring inside), slide onto the piston?
I have Goetze rings,
1. Does the oil spring expand with the oil ring when it's being installed? (I can't see a "break" in this spring like the other rings) 2. Does the spring "roll" down with the oil ring? I don't quite see how this oil ring with inside spring installs? Thanks
1969 911 E Coupe "Little Bull" "Horse" "H." Heart, "G." Gears, and "P" the Porsche |
Spring does have a "break", and there is a wire inside. Just find the break, spread apart and install _with_ the ring proper.
Hint: Install so that the break in the spring and the ring gap are 180 degrees apart. Chris
Chris https://dergarage.com ‘11 987.2 CS, '01 986S, '11 958S, '24 R1T, '87 Defender V8 |
You can also take the 'spring' out, place it in the land, then place the ring on top. Make sure the spring and rings gaps are not alligned.
I knew these rings would come in handy one day.....
Charlie Stylianos 1982 SC Targa www.Dorkiphus.com - (The Land of the NoVA/DC/MD Porschephiles) |
I think the last engine I did I used the method that Charlie described. Just don't spread those rings too far apart!
