John, I sent it to the aol account. Let me know if it works.
didn't see it in the mail box. You can send direct to jhelgesen@aol.com , or to jhelgesen@nc.rr.com
Thanks |
Okay, just need to fix the access to the outer intake stud on the head, put in a few fillets, should be golden.
http://forums.pelicanparts.com/uploa...1106182119.jpg |
Anybody have an SLDPRT file with the intake port basics in place for the 911 motor?
Kenik, sent you some igs files, should have the info you want.
I'm looking for someone that has access to a CAD program that has a stress analysis package. The application is spinning a custom metal wheel to see when it flys apart.
I found this old thread and thought someone here would have an idea. I don't have access to NX anymore so I need a CAD jock. I'm making the models in SketchUp. The design is simple, not a lot of detail, just trying to find out what general thickness of material to use and if we should use AL or steel. I would guess the model could be recreated in a real cad package in < 1 hour. In NX a "sketch" could be used and then the dimensions could easily be changed. Please PM me for leads or reply re. interest here. Thanks. |
| All times are GMT -8. The time now is 10:14 AM. |
