Starting Problem
After a long run at high speeds, my car would not start. I had this problem previously but it seemed to have cured itself....well, apparently not. This only happens when the engine is hot after a long run. Once the engine cools down, it starts again with no problem. I suspect the solenoids need replacing. Any comments ?
Old 01-12-2005, 10:39 PM
check out http://www.pelicanparts.com/techarticles/911_starter_install/911_starter_install.htm
Old 01-12-2005, 10:44 PM
kqw kqw is offline
What year is your car?
It does sounds like a solenoid prob with the starter.
The Fox
Carrera
Old 01-13-2005, 07:18 AM
Possible different answer for CIS cars vs DME cars...
For CIS..maybe need a better/replacement check valve at fuel pump discharge.....
Need to know car model....
Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 01-13-2005, 07:24 AM
My car is a 1988 3.2 Carrera. Any other views ?
Old 01-13-2005, 07:38 PM
kqw kqw is offline
When it does not start: is it cranking/turning the engine? or is it no crank response to turning the key?
If it's nothing, I would lean towards the solenoid on the starter.
Regards
The Fox
Carrera
Old 01-13-2005, 07:42 PM
