Original Owner
tsuter 78 911SC Turbo Targa Thaaaats Right!! |
Guys,
A properly done PPI is a sequential process. You do the most productive and least expensive things first. Then on to step two, three and so on. An ignition scope and tail pipe CO & HC check will give some valuable initial information at almost no cost. If there was impaired cylinder(s), a visual of the cap & rotor may eliminate that possibility. We had a test set of wires and plug connectors for a quick swap. Next would be a sump plate/ filter inspection. First decision point, do we continue? At this point there is labor, sump gaskets and oil & filter. Next would be a combined cranking compression and cylinder leak test. Sparkplug inspection is a very important part. Second decision point, do we continue? Remove the intake valve covers and check the intake valve clearance properly and the exhaust with a long feeler (not the way to set valves, just a rough check.) Measure the cam timing. It is remarkable how many engines can still run with the cam timing off. Of course the mechanic is inspecting and testing many other things here. The point is there is a progressive sequence. Only some shyster would continue when major problems were found in the first or second steps. The other issue is communication. I would insist that the buyer be readily available by phone so we could report the findings and get directions. The critical part of the loop is what the buyer wants. It is up to the PPI shop do accurate testing and to give good advice and council as to what is worthwhile or a waste of money. Many times the buyer wants all the info to negotiate an appropriate price. A few years ago I spent $600 for several PPIs finding Karen another $4500 early Land Cruiser. Money well spent to find the right ‘84. We started with 119K and now have 330K with very few repairs. Best, Grady
ANSWER PRICE LIST (as seen in someone's shop) Answers - - - - - - - - - - - - - - - - $0.75 Answers (requiring thought) - - - - $1.25 Answers (correct) - - - - - - - - - - $12.50 |
Thanks Grady for your input! Also very helpful.
Paul
If it flows, it goes. If its smooth, it moves. Any questions? 96 993 C2 (Current) 87 911 Factory Turbo-Look Cab (Sold) 85 911 Factory Turbo-Look Targa (Gone) |
Author of "101 Projects"
In general, there's tons of misinformation in this thread. There is no such thing as a bullet-proof test. Simple carbon build-up may skew leakdown tests for a single test, then clear up on the highway. Ditto for the compression check. You must evaluate all of the circumstances together as a whole and not depend upon a single test. Again, read this article - it's the best intro on how to evaluate your engine's condition: http://www.pelicanparts.com/techarticles/mult_Engine_Rebuild/mult_engine_rebuild-1.htm -Wayne -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Team California
I understood what you said perfectly.
What I said, on the other hand, is that a clean sniffer test would pretty much eliminate the need for a leakdown test, IMO anyways. Yes, many other factors could cause high HCs, (or CO), but take the logic in the other direction: could a car that fails a LD test post good HC #s? I think that compression tests are more useful in general, unless you already have determined a leakage issue from the CT and want to investigate further. If it was my PPI, and the car had less than excellent compression numbers, I'd factor at least a future top-end job into the price, or walk away.
Denis |
