Stereo configuration question for stereo dudes
For the stereo gurus:
If you had a 4 speaker receiver, 4 x 10 watts, with a DIN pre-amp output that drives 2 speakers, how would you wire the system? (Assuming that the 4 speakers were good, 5.25ish size modern coaxial speakers, and you have a 2 x 50 watt amp).
1. Drive the front two speakers directly out of the receiver, and the rear two speakers through the DIN output and the amp?
2. Same as 1, but the front speakers driven by the amp and the rear by the receiver?
3. Run the speakers serially so they are all driven by the amp?
Old 01-14-2005, 09:58 AM
kbruz's Avatar
I think this depends more on perference. This is my next planned project. I plan to use the amp for the front speakers and a sub. I'll drive the rear speakers from the head unit.
kb
mercedes GLK350
2009 boxster s
86 targa
Old 01-14-2005, 10:12 AM
I would buy a second 2 channel amp and run splitters (1 into 2, radio shack) off the din, but then you won't have a F to R fader.
If that's not an option, I would go w/ choice #1.
If you run the speakers in series, you may run into impendence(sp?) issues. You would basically cut the sound quality in half, w/ speakers that small, you may be able getting by with running all four pos to pos and neg to neg.....If I recall correctly.
SG
'69 912"Bastard"
My Porsche can't cook or clean....
Oh, wait, neither can my wife!
Old 01-14-2005, 10:14 AM
Registered Cruiser
jorian's Avatar
Brian,
I'm just now updating the tunes in my rig as well. A high-end shop is doing the install and has recommended the following:
1. Keep head unit (Blaupunkt 35w x 4) - they didn't try to sell me a new one!
2. 4 channel Amp to drive sub and door speakers (2 channels to speakers 2 channels combined for the sub)
3. Head unit to drive the rears
As the majority of the sound comes from the doors they suggested amping those rather the rears as I had thought.
By the sounds of it (no pun intended) your amp might be a little anemic to run the doors. I could be wrong.......
Good luck.
87' Carmine Red Carrera - Keeper
82' Silver SC - Sold 79' Gran Prix White SC - Sold
05' Black C2S - Daily driver
I have never really completely understood anything.
Old 01-14-2005, 10:15 AM
echrisconnor's Avatar
I'd say go with option 1. You really do want to have the front/rear fading capability, and the rears usually end up running at a higher level than the fronts -- so put your amp there. If it's a good quality head unit, 10 watts is a decent amount of power if you're not trying to rock out the world with massive bass.
Another option is to get a line level converter for your front channel and then a second amp. The line level converter will take your 10 watts and drop it down to under 2 watts which is an appropriate input level to run via RCA cables into a second amp. This will allow you to retain your F/R fading.
'76 911 Carrera 3.0
Old 01-14-2005, 10:19 AM
Thanks guys. Buying/installing another amp is not an option!
No. 1 was my plan - I'll go with it.
I'm not really big into stereos, most of my cars have had total crap. This setup is slightly better than most I've had, but that's about it.
I'm not buying any new stuff, this is just reconfig work.
Thanks again!
Old 01-14-2005, 10:41 AM
Oh - one other question. With 5.25 speakers, is it really worth running the amp at all? Or should I just plug the 4 speakers into the back of the receiver and call it a day?
If the receiver were like the one's I've had before (35 x 4) I'd just skip the amp. The 35 x 4 sounded plenty good for me. But a 10 x 4 receiver . . . is that really low power that needs an amp?
Old 01-14-2005, 10:47 AM
Registered Cruiser
jorian's Avatar
If you have an amp use it. A 10 x 4 reciever is good for talk radio.........
Old 01-14-2005, 11:00 AM
10 x 4 usually will mean 20 x 2 or there 'bouts, use the amp and two.
'69 912"Bastard"
Old 01-14-2005, 11:03 AM
Send a message via Yahoo to Lukesportsman
Unless its just for principle or funds are really tight, I'd due as echrisconnor suggest with one difference: buy an inexpensive namebrand amp with low THD from Walmart with high level inputs. Its not audiophile but more amps will be a LOT kinder to the speakers and less likely to blow one with the windows down on the highway.
This is unless your just doing talk radio and then 1. would "work".
Luke S.
72 RS spirit 2.7mfi, 73 3.2 Hotrod on steelies, 76 993 3.3efi TT, 86 trackrat, 91 C4s widebody,02 OLA winning 6GT2, 07 997TT, 72 914 v8,03 900 rwhp 996TT
Old 01-14-2005, 11:46 AM
D idn't E arn I t
RANDY P's Avatar
Definintely use the 2x50 to run the front speakers, deck power to the rear. Use the size of the fronts to get the volume and frequency response.
Wiring everything in parallel (all 4 off of two channels) will effectively limit your output to what the rear speakers are capable of handling and be annoyingly tinny. In fact I wouldn't even bother with rear speakers, not enough cone surface to contribute anything useful - effectively a limiting factor in sound quality.
rjp
AOC/Hogg 2028
Old 01-14-2005, 11:53 AM
