Which Brake Ducting Kit
I want to install ducting to my front brakes - I've seen the kit here on Pelican and I see that there is an AJ Racing kit as well as an OG Racing kit - I'm not sure if any of these are actually the same, but I'm looking for advice on which is the 'best' to get - pros and cons of each - or are they all the same?
Thanks. |
I have the OG one and it works great.
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
Memory only speaking here....others, kindly check....
I think the OG kit is 3" hose ( better) but routing becomes a problem and the f'glass scoops are reportedly very grody looking.... The AJ Racing kit is 2.5" hose, but is easier to route, and the kit has high quality looking aluminum scoops. Both pick-up air underneath the car...not ideal ( better I guess would be front valence mount...like through fog light openings....higher pressure cleaner air entry). Look at archives for this. There are linked tech articles to some West coast PCA clubs, too ( Steve Groeskemper ?....Orange county region ??) EDIT...see April and May 2002 articles, here... http://www.dietersmotorsports.com/tech_articles.html Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) Last edited by Wil Ferch; 01-13-2005 at 08:48 AM.. |
IOPort racing sells a nice plastic duct that will fit almost perfectly into the fog light opening ($20):
http://www.ioportracing.com/Merchant2/merchant.mv?Screen=PROD&Product_Code=BD-1&Category_Code=DAA Then you can modify your dust shields as such:
'75 911S 3.0L '75 914 3.2 Honda J '67 912R-STi '05 Cayenne Turbo '99 LR Disco 2, gone but not forgotten |
MichiganMat:
I see we meet again in cross-posts ! ![]() your set-up is fine but presents problems for guys like me who have a huge washer bottle in the same place on the drivers side. I know, I know...we can fix that....but I'm trying to avoid fixing unrelated things that are working well as it is..... Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
Wil:
Ah-ha! I have you now, there is no escape!
Bandwidth AbUser
I have the OG Racing kit. It works very well.
Jim R. |
Are any of these kits designed for the early (- 73) cars?
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
I did the following...
993 deflector plate Remove splash guards Install smart racing block off plates Super blue fluid Have not experienced fade in 100 miles of track driving running metal master pads. Edit: Link to thread on this mod Brake Cooling Diverters Modified
88 Carrera Coupe Pelican Since 2002 All Zing, No Bling. ok, maybe a little bling. The Roach |
Brooke 1969 911 ST 2.8SS EFI ITB (Irish Green), 1974 911 3.6 ITB (Black) 1952 MG TD with F20C |
Anything under the A arm is gonna get ripped off, use 3" min ducts from the front valance, make a plenum around the A arm.
