Yellowbird RS's Avatar
Question Boxster calipers ????which rotors?????
After a lot of search I couldn't find which rotors I need
using Boxster calipers on my 74 Carrera.
X/A
Old 01-22-2005, 06:43 PM
VincentVega's Avatar
84-89 Carrera
Old 01-22-2005, 07:46 PM
Formerly bb80sc
Vipergrün's Avatar
You'll also need the adapters to bolt them up to your struts, if you have not got them.
Cheers
-Brad
2015 Cayman GTS
2015 4Runner Limited
Old 01-23-2005, 11:30 AM
hi,
i run the same setup on my SC. I'd advise going for the cross drilled version of the 84-89 rotor since the heat input to the rotors are substantially higher when using boxster calipers. Also watch out for an imbalance in bias between front and rear if you plan on running standard caliper on the rear ... fronts are prone to locking up very quickly
happy braking
pcar fanatic
Old 01-23-2005, 11:41 AM
Bill Verburg's Avatar
I agree w/ most of the above. The calipers won't get you much of a performance increase, about the same as using Carrera brakes which is a much cheaper proposition.
If you use the Boxster fronts on Carrera rotors, drilling will make any heat issues worse
If you use the Boxster fronts then you need either Boxster rears or Carrera rears for balance.
Bill Verburg
Old 01-23-2005, 03:41 PM
I have the 4 calipers (front and rears) from my Boxter S, so I will use them all around, the adaptors are in UPS alrady.
Ok so I need carrera rotors front and rears (drilled)????? yes, no on front only.
Do I need to change the master c...????
X/A
Old 01-23-2005, 05:32 PM
Boxster S calipers are not the same as Boxster calipers, they will want a thicker 28mm rotor, this is a problem. You could try the 944 rotor like VCI uses on their 963 kit or try to widen the throat to accomodate a 32mm 930 rotor.
Bill Verburg
Old 01-23-2005, 07:02 PM
hi bill,
you mention that drilled versions will make the problem worse. is this because reduction of surface area due to drilling does not outweigh increased heat dissapation through the holes?
regards
pcar fanatic
Old 01-23-2005, 10:18 PM
IROC's Avatar
Originally posted by pcar fanatic
hi bill,
regards
pcar fanatic
It's probably because drilling the rotors removes material which in turn reduces the "thermal mass" of the rotors. In other words, they can't absorb and then dissipate as much energy (heat) during braking.
Mike
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 01-24-2005, 04:39 AM
dickster's Avatar
as a matter of interest there is a write up on fitting boxter calipers in the feb 911 & PW (i only bought it for the 930 article).
it says the 3.2 and 2.7 calipers will not go under 15" wheels!?? WTF have i got under my 15's then!??
Rich
'86 coupe
"there you are"
Old 01-24-2005, 08:50 AM
Glasgow 911SC's Avatar
I think it's refering to the 2.7 & 3.2 Boxsters.
Chris
1982 911 SC Hellblau Metalic
1997 Boxster 986 2.5l
Old 01-24-2005, 12:03 PM
yes, and the fact that those rotors were never designed to be drilled and the fact that they are small(mass) to begin w/ unless you have a near 2k# car.
The wheels they fit under is highly dependant on the rotors used.
Bill Verburg
Old 01-24-2005, 12:12 PM
dickster's Avatar
oh ok, thanks, dooh! can you tell i'm not a boxter fan?
Rich
'86 coupe
"there you are"
Old 01-24-2005, 02:13 PM
So the best thing to do is sell them and get a 964/944turbo calipers, ........RIGHT?!
Hey! Bill, can you tell me the correct spacers to fit Boxster S wheels in my car they are 17"x7 front et 55 and 17"x8.5 et48 rear.
Thanks!
X/A
Old 01-24-2005, 04:07 PM
No, a Brembo kit is best, but Steve Timmins may be working on something that may help you w/ the brakes.
front spacers will want to be ~30 - 32mm, rear ~13 - 16mm
Bill Verburg
Old 01-24-2005, 07:27 PM
Bill.
So my new ET going to be 55mm-(30-32)=25-23mm front
and 48mm-(13-16)= 35-32mm rear
It}s that right?
Thanks.
X/A
Old 01-24-2005, 10:51 PM
Sorry, I wrote that backward , the rear should be 32 - 35mm spacer for an o/s of 13- 16
Bill Verburg
Old 01-25-2005, 04:45 AM
