-   -   Turbo trailing arms or alum SC? (http://forums.pelicanparts.com/porsche-911-technical-forum/201661-turbo-trailing-arms-alum-sc.html)
ted 01-15-2005 12:11 PM
Is it worth it to convert to the turbo trailing arms for an 85% track car?
Anyone have experiance with results, before and after a turbo arm conversion?
Turbo control arm pluses, bigger wheel bearings, anti squat, less camber change during suspension travel, better rear bump.
But is it going to lower lap times?
thanks,
masraum 01-15-2005 12:43 PM
I think there's also the issue of the turbo arms relocating the wheels tires which usually requires flares. I think you can also accomplish some of the same stuff by changing the mounting of the stock style arms.
Rick Cabell 01-15-2005 01:42 PM
A while back I had the opportunity to buy a pair of 930 arms for cheap, and posted the same question. My recollection is that they make a marginal difference, and given the labor involved in swapping them, it doesn't make a whole lot of sense. You could probably find the thread with a search...
