Alii&Maui
Jesset100's Avatar
I just had to share this
This was a little project. Install rear speakers and run new wire to them. I wanted to do like the factory did and run the wires under the carpet so, I pulled the carpet and the factory wire is under the padding not the carpet.
I thought of the situtation and said to myself "Self just run the wires under the carpet and leave well enough alone". But something deep down inside said pull the padding up so I did.
I was totally shocked at what I found. Water was puddling up in the seat area!! The padding has a rubber shell and the back side has the padding. Well, the padding was soaking wet, I mean I could wring water out of the padding! Can't upload more it won't let me
The good news is NO RUST
1982 SC Coupe
SCWDP#0087
KCSSL#0082
Old 01-15-2005, 05:34 PM
Banned but not out, yet..
RSBob's Avatar
YIKES!! Better check your rear window seal.
Old 01-15-2005, 11:02 PM
Alii&Maui
Jesset100's Avatar
Funny thing is I don't drive in the rain. The rear speaker shelf has the same rubber/insulation padding and it's bone dry. I think the water was comming from the rear seat belt mounting holes. (I think) I drove around a couple of weeks ago after it rained, but the road was mostly dry execpt for a couple of wet places. Oh yea I haven't washed the car in 6 months. The water had to come from under the car.
1982 SC Coupe
SCWDP#0087
KCSSL#0082
Old 01-15-2005, 11:23 PM
Maybe some of your more spirited driving caused the car to wet itself. I think I probably scared my car on the odd occasion.
Old 01-16-2005, 01:06 AM
rfuerst911sc's Avatar
This is a good time for some weight reduction,once you find and repair the leak replace that old HEAVY OEM pad material with newer lightweight insulation.I went to Home Depot and purchased a roll of silver foil type insulation,it is shiny foil on both side with a foam like core sandwitched in between,it is light as a feather compared to OEM.It is easy to cut and form and you can either glue it in place or use 2 sided tape like I did,I think I saved about 40 lbs. or so.
Old 01-16-2005, 03:38 AM
jacko241's Avatar
maybe the heater core is leaking....
Joe
996 GT3 RSR
Old 01-16-2005, 07:52 AM
atlporsche's Avatar
LOL!!!!
sjd
Porsche sold, moving back to muscle cars for a bit.
Old 01-16-2005, 07:57 AM
Did the car sit out in the rain ?
Old 01-16-2005, 08:13 AM
djmcmath's Avatar
My PO let the car sit outside for 4 years in the Pacific Northwest. Dumba$$. Anyway, the first thing I did when I got it was pull out all of the loose carpet and dry out anything I could reach. I thought I had it all....
...Then last weekend I pulled out all of the glued down carpet and sound damping. I found exactly what you did -- soggy padding! Mine was so bad I was growing fungus!! Fungus, I tell you!
I'll ditto the "get some lighter modern sound damping" posts. I would also suggest that pulling up absolutely everything from the back seat and painting with POR-15 is probably a good idea. But I'm crazy like that. I've POR-15'd wood before, just to make sure it doesn't rust. Have fun!
Dan
'86 911 (RIP March '05)
'17 Subaru CrossTrek
'99 911 (Adopt an unloved 996 from your local shelter today!)
Old 01-16-2005, 08:31 AM
PCA7GGR's Avatar
If you car has a sunroof, check to make sure that the drain tubes, which come out aboute the corners of the rear window, are clear. You should be able to run a wire up through the holes.
Sergio
The GT Lid Whisperer
PCA 42yrs - National DE Instructor / Ex-RGruppe #197
'19 718 Cayman S (9th Porsche/1st with PDK)
'14 Subaru Forester XT (Porsche support vehicle)
Old 01-16-2005, 09:05 AM
