How does oil get on top of the motor?
I removed my fan /alt assembly yesterday because it seemed to have shifted and I have been wanting to repaint the fan housing anyway.
Once I got it all apart I noticed about an 1/8 inch layer of oil mixed with dust on top of the case. It seems I have been acquiring more mysterious oil leaks lately that at some point I will have to do something about. Leland mentioned checking the torque of the rocker arm shafts at my next valve adjustment that I have been procrastinating on. Anyway, The oil on the top? Overfill discharge? I have wondered where the oil goes if you overfill. I don't think the picture helps because the air diverter is still in the way.
1979 911 SC Targa http://www.pelicanparts.com/gallery/Mike_Kast |
Somewhere in the Midwest
The CIS airbox has a small drain under the air sensor plate. The hose under there could have come loose at some point and the PO overfilled it. Also, the crank cast breather housing and hose (clamp) could be leaking. The T-stat or idiot switch could leak oil to that area too. I would check all those. Some of this is better done w/ the engine out.
Maybe you have the same leakage that I had/have.
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
Little German gnomes were installed at the factory to carry tiny buckets of oil to various places in your engine bay. Forgive me, it's the best theory I can come up with to explain oil in some places...
'86 911 (RIP March '05) '17 Subaru CrossTrek '99 911 (Adopt an unloved 996 from your local shelter today!) |
Breather cover is my most likely choice ... thermostat O-ring and oil-pressure switch follow on the list!
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
How about the breather tube/hose that runs to the oil tank . Or the drain port in your airbox which is also plumbed to the oil tank .
Kurt Williams
Never drive faster than your gaurdian angel can fly. 82 SC w/965S eng and G50 6:1 hp/w ratio 72 911t 2.6 twin plug and 72' 911t 57k orig 1 own miles 65/66 912 1 owner 76k orig 01' Aston Martin DB7 V12 Vantage Coupe 6spd |
I'll go with Warren's answer on this one....I recently pulled a rather nasty engine/transmission (i.e. lots of oil on the bottom and the top rear) on a '74 P-car and traced most of the oil leaks to bad breather/thermostat gaskets and a sending unit, all of which are located at the rear of the engine...much easier to repair with the engine removed.
Marc Morrison 1964 356C coupe '89 911 coupe 2008 Honda Accord 2008 Ford Ranger |
