RazorRacer's Avatar
tranny prob after going off track 78SC
I went off track yesterday and hit a mound of dirt going around 70 mph. Dirt flew over the car and caked the bottom of it. Not much visible damage, but the tranny is not grabbing the gears, especially 3rd gear and reverse.
I'm going under today to clean it and then I will try to adjust the shifting linkage. Any ideas what happened to the tranny?
Stopped racing and became a drummer
Old 01-16-2005, 10:42 AM
Grady Clay's Avatar
Is the clutch properly operating? Does it fully release so you can put it in reverse and other without reverse gear clash or syncro balk? The clutch arm, cable, etc is a low point and subject to getting caked in this situation.
Has the shift lever moved position?
Does the throttle operate properly?
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 01-16-2005, 11:06 AM
RazorRacer's Avatar
Everything works fine, but the clutch feels light and 3rd gear won't stay in place. Perhaps the caking in the underneath clutch area is causing the problem. The car just now got jacked up to the point where I can go under and clean. I'll report back in a few minutes between cleaning and watching the football game.
Old 01-16-2005, 11:10 AM
RazorRacer's Avatar
This might be the problem...
Old 01-16-2005, 11:17 AM
Me like track days
Craig 930 RS's Avatar
I like the 'book as jack pad' -
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 01-16-2005, 11:18 AM
PorscheGuy79's Avatar
Some people, like myself, didnt really enjoy math...
Matthew
“Sometimes the questions are complicated and the answers are simple.”
Old 01-16-2005, 11:23 AM
RazorRacer's Avatar
It's the 'Book of Knowledge' and it helps me understand my car.
It's cleaned out, but 3rd gear has way too much slop. What should I check?
Old 01-16-2005, 11:29 AM
If car was in third when you hit "the problem" you may have "readjusted" the shift rod coupler. Search for shifter adjustment threads.
Scott
Old 01-16-2005, 11:35 AM
RazorRacer's Avatar
Yup, it was just an adjustment and problem solved. How did the hit in 3rd gear cause the mis-adjustment?
Old 01-16-2005, 02:19 PM
The enine was dragged rearwards in the chasis, the shift lever was pulled to the very front edge of the shifter assembly - until it reached the limit, the engine and transmission continued towards the rear of the car, dragged by the mud....then the main shift rod, in tension, relieved the excess load by slipping the coupler....
You still might have some minor internal distress, or reduced life on the 3rd gear drive teeth.
Regards
Hayden
Old 01-16-2005, 03:08 PM
