these tail lights for a '84
does anyone know if anyone makes these tail lights or somthing simiar for an '84 carrera?
Old 01-23-2005, 01:52 PM
rdane's Avatar
I have a set in my '79. Bought them from Pelican.
Old 01-23-2005, 02:20 PM
but will they fit in an '84?
Williamknightperformance.com
Perfectpower.com
Old 01-23-2005, 02:31 PM
just me
paulgtr's Avatar
Send a message via Yahoo to paulgtr
they should, aren't they RSR tail lights?
1975 911s, 3.2l and 915 transmission front oil cooler RUF replica bumper ducktail and SC rear flares SW chip ssi's m&k 2 in 1 out sc front calipers PF 97 pads fuchs 16 x 7 and 8 225/ 245 toyo ra-1s 22/29 torsion bars 25mm Charlie Bars Neatrix bushings lowered and corner balanced DAS bolt in roll bar kirkey seat 5 point harnesses.
http://www.hairydoggrrrage.com/
Old 01-23-2005, 02:34 PM
Somewhere in the Midwest
MotoSook's Avatar
The fiberglass housing will fit the 69-89 911's, but you may have to fool with the screw holes a bit. Not a big deal, but the housing/panel outline is almost identical to the lense of the 69-89 cars, so they will fill the void once you remove your stock buckets and lenses. You then have a choice of regular bulb lights and the Hella lamps or LED lights.
Old 01-23-2005, 02:37 PM
Administrator
Jack Olsen's Avatar
They're R taillights, and they'll fit any 1969-1989 911.
Pelican and TRE Motorsports sells the good ones.
Thank guys, awsome
Perfectpower.com
Old 01-23-2005, 02:40 PM
rdane's Avatar
No problem in a '84 but nothing over 300 hp sorry
Old 01-23-2005, 02:47 PM
