In the shop at Pelican
Jared at Pelican Parts's Avatar
Tranny to Body Ground Strap question
Is there a way to check is this is the cause of the intermittent starting probelms im aving lately? I'm thinking ground strap as my instrument lights sometimes brigthen with revs and the alternator is ok.
What resistance values should a typical ground strap have? BTW, ive already replaced the battery to body strap...
Old 01-18-2005, 12:14 AM
You can run a fake ground off the tranny to some other ground area. The problem with ground problems is that the slightest movement can cause whether the car will start or not. Not sure about the 83 but if the car has a CD box, check the ground coming off the plate it rests on. Where it grounds to can get quite dirty.
Good luck.
Old 01-18-2005, 06:16 AM
Alter Ego Racing
ErVikingo's Avatar
Jared,
The strap is so cheap that IMHO you should just change it. Its certainly cheaper than the clutch cable which I ahd to replace 3 times until I realized it was the ground strap.....
Ground strap will also light up the brake light, cause hot starting problems and dim headlamps and instruments (from my experience).
International GT Champion; Porsche GT3 Cup Trophy Champion; Klub Sport Challenge Champion; Rolex Vintage Endurance Series Champion; PCA Club Racing Champion; National Vintage Racing Champion
Old 01-18-2005, 06:46 AM
vizail's Avatar
Jered
You can also clean and lube the connector at the rear at the rear defog relay and fuse box(3 Fuses). Cleab w/ contact cleanner the lube wiht dielectric grease
Hope this help
Vic
Old 01-18-2005, 07:25 AM
Senior Member
My tranny ground strap was causing a false low oil pressure reading and hard hot starts. Picked up a nearly identicle strap at autozone for $2.50
78 Euro 911sc Targa
03 Hayden
SCWDP
Old 01-18-2005, 08:03 AM
