Door "wing" window question
It seems that the fixed window on the door is about 1/2 inch too low at the top. Is this adjustable, to loosen something inside the door and slide it up a bit. There is a gap at the top to the targa roof when the door is closed.
Anyone try to make adjustments to bring the whole front of the targa roof "down" tighter? (87 targa)
PCA and BMWCCA member for many years 09 Boxster Base PDK (No spare tire) ![]() 05 M/B CLK 500 AMG (Spare tire) ![]() 07 BMW 530xiT (Spare tire)
Daka--
Targa Vent Window thread As you'll see in the thread above, there are a couple of things to consider in this regard. Make sure that the corner seal between the main window and the fixed wing window is in good shape and that the main window does not ride up too high. If that is OK, then yes, the vent window assembly can be moved. You'll have to remove the inner door panel to get at the bolts holding it in place. If you don't have a Bentley's manual, you might want to get your hands on one. It explains the process well. All said and done, its a never ending battle - ask me how I know! Good luck
Steve My '85 911 Targa ** Hand painted center caps for sale here RIP Warren PCA & Rennlist member |
