Carbon Emitter
Barn find #2: '73 911E Viper Grn w/rare options
removed
I can only help with question 2 - to wit see if a magnet sticks to it. If yes then steel. If no, then SCORE!
Jamie79SC |
Senior Member
Wow.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
Old Member
3. Turn the motor by hand and look or feel the MFI cog on the back of the pump to determine if it's turning.
Clifton Brown https://www.mancalamarketing.com |
PRO Motorsports
With MFI, the volume of fuel is very low coming out of the MFI pump. It's noit like CIS. The little plungers that pump the fuel are timed with the engine, and only squirt when the intake valve is open. They are very high pressure though, since the injector nozzles don't open until around 220-240 PSI
What you should do is put in some fresh fuel, a fresh fuel filter, and make sure you have spark.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer) '72 911T Targa MFI 2.4E spec(Formerly "Scruffy") 2004 GT3 |
Great find!!!
Yes ... Bosch H4 lenses are readily available from our host! 1. My suspicions are that you need to pull the MFI components off and clean them thoroughly in B-12 Chemtool before trying to fire up the engine! Change out/rebuild 100% of the factory rubber fuel hoses to guard against fires of the sudden and painful kind! Especially the cold-start supply lines! 2. Disassemble and clean the entire brake system ... rebuild those parts not beyond repair. 3. Disassemble and clean eveything electrical ... 5-pin, 6-pin, 14-pin connectors, etc. attached to the engine and dash/instrument panel ... lube all connection with Dow Corning 4, 111, or 112 Silicone Grease AFTER verifying proper operation! It sounds like an arduous task, I know, but the rewards will be many ... paint restoration won't be simple, either!
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
Carbon Emitter
Good advice...I've been a victim of an engine fire before! Just did the magnet test (duh!) and it's just a steel decklid. And I just discovered that it doesn't have S brakes!!! Who would order their 911 with these goodies and skip the brakes? Strange... Last edited by jkarolyi; 01-10-2005 at 07:34 PM.. |
Congratulations. Should be a fun project.
My '73E 'barn find' was a 'driveway find' for $2800... with a priming shot of gas, it started and ran beautifully after 6 years of storage. No smoke (after the first 40-50 minutes) and never a drop of oil on the floor... Still ended up spending about $9K on it.
techweenie | techweenie.com Marketing Consultant (expensive!) 1969 coupe hot rod 2016 Tesla Model S dd/parts fetcher |
Lordy, Lordy. Red over green. Haven't seen that since.....about a hour ago out back.
We need to meet up. Start a support group or something. You have a bunch of money that you don't know what to do with (or did), just like me (especially the 'or did' part).
Dude, play the lottery........lightening twice......we should all be so lucky
Dan '87 Targa |
Don't let Alex see this one. IF you do, you can double your money overnight.....
Bob S. 73.5 911T 1969 911T Coo' pay (one owner) 1960 Mercedes 190SL 1962 XKE Roadster (sold) - 13 motorcycles |
One item to add to the bottom of Warren's list before starting;
Change the oil and filter. Then remove the plugs and crank the engine on the starter until oil-pressure registers on the gauge (I assume that you have S instruments) or the oil pressure light goes out. Then install new spark plugs and start her up. (PS: Guys like you make me sick!!! ) in a good way!
John '69 911E "It's a poor craftsman who blames their tools" -- Unknown "Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman |
You got to love those "barn finds".
1974 911s "It smelled like German heaven" http://www.youtube.com/watch?v=6ySt9SeZl9s |
Re: Barn find #2: '73 911E Viper Grn w/rare options
Very cool find! You will have to pay PCNA to get the build list for your car...I think it's about $90. No free Cardex like other manufacturers. I'd like to add to the Fresh fuel advice, Drain the old stuff out first . Be thankful you have the plastic tank as many have had chronic fuel delivery problems with rusted steel tank interiors.
Warren & Ron, may you rest in Peace. |
Carbon Emitter
Thanks for the MFI advice.
I've already researched the "starting a long-stored engine" threads, so I think I'm pretty prepared for that, but thanks for the advice. Does anybody know the answers to the Euro equipment question (#5)? Last edited by jkarolyi; 01-11-2005 at 11:20 AM.. |
Warren Hall Student
5. Euro cars had black grills and signal trim but had chrome bumper guards. Basically they were like the US car but with chrome bumper guards and H4's instead of sealed beam headlights. Also the speedo was KPH.
P.S. I just remembered that some of the 73' euro cars had the chrome type bumper guards but they were painted black. They however didn't come with the the big rubber guards.
Bobby _____In memoriam_____ Warren Hall 1950 - 2008 _____"Early_S_Man"_____ Last edited by Bobboloo; 01-11-2005 at 11:07 AM.. |
Stay out of the barn's.I'll go first next time.
Carbon Emitter
Some "after pics". Larry's '73 Viper Green 911E was repainted red too before it was restored to this level, so it is definitely an inspiration for me! What got into everybody's head in the 80s to repaint these things guards red?
Warren Hall Student
Here's an "after" shot of my Signal Orange 71'S that's now a "before" shot since I'm taking it back to the future "Signal Orange".
Bobby _____In memoriam_____ Warren Hall 1950 - 2008 _____"Early_S_Man"_____ Last edited by Bobboloo; 01-11-2005 at 07:21 PM.. |
Carbon Emitter
>The same thing I guess that made them think painting them white with black out trim was cool.
Yeah...my old '71 911E Targa was like that too. Last edited by jkarolyi; 03-11-2006 at 05:03 PM.. |
