-   -   Show me your - Adjustable Camber / Castor Plates (http://forums.pelicanparts.com/porsche-911-technical-forum/202467-show-me-your-adjustable-camber-castor-plates.html)
doozer 01-20-2005 10:11 AM
I need photos of Adjustable Camber / Castor Plates for the front struts.
Also photos, drawings, and dimensions of the boxed front Adjustable Camber / Castor Plate mounts.
Thanks Everyone!
Todd
doozer 01-20-2005 10:59 AM
Do they make something like this for 911??
http://forums.pelicanparts.com/uploa...1106251156.jpg
Todd
Jeff Alton 01-20-2005 11:17 AM
I think they do but they require you to weld in new strut tower boxes.
Try SRP
Jeff
doozer 01-20-2005 11:19 AM
Yes I need photos of strut tower boxes also!!!
Todd
Mike Bonkalski 01-20-2005 11:47 AM
From the Smart Racing .pdf catalog:
http://forums.pelicanparts.com/uploa...1106254024.jpg
Ove 01-20-2005 02:07 PM
I don't have adjustable camber plates myself, but take a look here:
http://www.redlinerennsport.homestead.com/OBrien1.html
(at the bottom of the page)
Jack Olsen 01-20-2005 04:49 PM
One note: if you're getting struts custom made, or even if you're raising the spindle on existing struts, you can add static camber without having to get the expensive doo-dads.
doozer 01-20-2005 05:04 PM
Yes!!!!
Thanks Guys!!!!
0.25 steel top
0.125 steel sides
http://forums.pelicanparts.com/uploa...1106272350.jpg http://forums.pelicanparts.com/uploa...1106272367.jpg http://forums.pelicanparts.com/uploa...1106272379.jpg http://forums.pelicanparts.com/uploa...1106272398.jpg http://forums.pelicanparts.com/uploa...1106272842.jpg http://forums.pelicanparts.com/uploa...1106272981.jpg http://forums.pelicanparts.com/uploa...1106273023.jpg
doozer 01-20-2005 05:05 PM
Please walk me through it Jack!
Zeke 01-20-2005 05:15 PM
He's just saying that when you cut the spindle free from the strut, you can reweld it in the raised position with a little built in camber. A little grinding on the inside will do the trick. Very small changes on the spindle can do a lot compared to having to move the top of the strut.
doozer 01-20-2005 05:20 PM
EEEEK! - Off to my machine shop!
SmartRacing:
Box.................... 453010.......... $433.00
Camber Plate.... 452310.......... $310.00
doozer 01-20-2005 05:23 PM
Got ya! Thanks Milt!
widebody911 01-20-2005 05:44 PM
Be sure to use lots of castor oil when you assemble those.
project935 01-20-2005 06:20 PM
Mine are pretty simple.
These (0.120 plate w/welded on spherical bearing sleeve);
http://forums.pelicanparts.com/uploa...1106277442.jpg
Sit on top of these (0.25 plate supported by tubular structure);
http://forums.pelicanparts.com/uploa...1106277592.jpg
doozer 01-21-2005 07:21 AM
Great Tip Thom! Do I rub it on my tool wench or the car?
Project935 do you have any drawing with diminsions you would be willing to share??
I found that QA1 makes an adjustable plate to fit their adjustable struts ( the ones I am using at the center of the air ride system ) but I will still need to fabricate a base for them.
Thanks for all the help!
Todd
project935 01-21-2005 07:52 AM
I have CAD of the plate/sleeve I can send anytime.
I still need to CAD the base on my chassis - might be able to get to it this weekend.
doozer 01-21-2005 07:54 AM
Wow, could you send it to porschev8@hypertec.ws
Thanks!
Todd
doozer 01-21-2005 08:13 AM
I might as well go ahead and do the rear while I am at it..
http://forums.pelicanparts.com/porsche-911-technical-forum/192377-anyone-have-cad-drawing-oem-adjustable-springplate.html
doozer 01-21-2005 09:37 AM
Woo Hoo $154.00
These are the plates that will work with the QA1's I am getting!
http://forums.pelicanparts.com/uploa...1106332606.jpg
project935 01-21-2005 09:41 AM
That's super cheap!
You need to make sure it will fit in the general vicinity of the OE shock tower and still allow for a decent adjustment range - my first guess is that they look kinda big.
