Need wiring help for a second alt warning light.
What's the best way to wire a second alt warning light.
I currently have one wired to the stock alt warning light. It worked once upon a time but has not been operational for some time now. I've checked all of the obvious things. I suspect there's a better way to wire these things than to just piggy back on the existing leads from the stock warning light. Any suggestions? |
try installing a volt ga
How would one wire that?
i did this with led's, and the oil pressure also.
this light will always let you know if the fan belt broke. here's the thread http://forums.pelicanparts.com/porsche-911-technical-forum/157105-custom-cht-guage-install-lights.html?highlight=cht http://forums.pelicanparts.com/uploa...1081228386.jpg |
| All times are GMT -8. The time now is 08:37 PM. |
