IAN IAN is offline
Torque Spec for Intermediate Shaft Cover nuts?
I'm replacing this gasket. Does anyone know the torque spec for these nuts?
Thanks.
Old 01-21-2005, 12:15 PM
KTL KTL is offline
Schleprock
KTL's Avatar
Snug.
Just kidding. I'll look it up if no one else chimes before I can get at the manual or spec. book. I can guarantee you it will be quite low.
If the valve covers are 6 ft-lb (M8 nylock nuts), the M6 nuts on the int. shaft cover will be even less. Hope you got an inch-pound torque wrench!
I believe the Bentley says 8 Nm = 6 ft-lbs for the chain covers which should be about the same for the int. shaft.
Kevin L
'86 Carrera "Larry"
Old 01-21-2005, 01:25 PM
johncj8989's Avatar
Something about seeing the words torque and nuts in the same line that makes me twinge.
Chaos, panic and disorder . . . my work here is done
Current Stable:
Maserati GranTurismo S
Range Rover Autobiography
Various Porsches ~ in pieces
Old 01-21-2005, 01:58 PM
