HarryD's Avatar
Originally posted by HarryD
Randy,
When I get to work next week I'll ask the guys in the shops.
I checked with the guys in the Air National Guard Corrosion Control (metal work and painting) Shop about the Technical Order concerning Simple Green. He told me that it is true that Simple Green is not allowed on the base. However, it is not it's corrosive effects on the metal but because of its effects on the coatings where it significantly reduces it's life and they need to strip and repaint more often.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 02-22-2005, 08:08 PM
Now in 993 land ...
aigel's Avatar
Why not use something that was designed to do the job, like engine degreaser? I got my engine and transmission spanking clean with "Gunk" brand engine degreaser.
George
81 SC (sold)
Old 02-22-2005, 10:35 PM
Hands down the best cleaner I have used is Eimann Fabrik Hi-Intensity All-purpose cleaner. Fairly high pH, I think simple green is about 9 where this stuff is 10 or more. The stuff is amazing.
CConnor
73E targa
89 Coupe
Old 02-22-2005, 11:08 PM
Not to roil the pot too much, but wouldn't plain old karosene also work?
I've used karosene for heavily soiled parts, and it simply "melts' gunk (petroleum by-products) away. And since it is soluble with lots of water, it is more environmentally friendly some of these other ".....enes".
What say you?
Andras
1983 911SC The Chocolate Kiss
1998 Audi A6 Quattro (Family Car)
2002 Audi TT Roadster (Wifey's Car)
1992 Mazda Miata (Daughter's Car)
1991 Honda VFR750F Interceptor
1982 Honda VF750S Sabre
Old 02-23-2005, 05:05 AM
simple green is listed with the faa as being caustic to aluminum and magnesium
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 02-23-2005, 05:19 AM
I think kerosene works well as a general degreaser....look also at "Oil-Flow"...I believe it is kerosene based...and I used it to de-gunk the wheel wells of cosmoline very successfully without attack to the PVC undercoating or paint.
Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 02-23-2005, 05:24 AM
scottb's Avatar
Wil: Do you have a web site for "Oil-Flow?" Google search didn't turn up anything. Thanks.
1984 Targa
Old 02-23-2005, 07:22 AM
I think I remember in the "old days' the firemen used to wash the firetrucks with a mixture of about a cup or two of kerosene to a bucket of water.
Boy, I'm giving away my age.
PCA and BMWCCA member for many years
09 Boxster Base PDK (No spare tire)
05 M/B CLK 500 AMG (Spare tire)
07 BMW 530xiT (Spare tire)
Old 02-23-2005, 07:31 AM
nice doggie
Hetmann's Avatar
steamer
Sorry about the delay in getting back. I bought one of those little steamers and have used it to clean several items. The stream of steam it generates is useful for small areas and works well when combined with a solvent and elbow grease. I have my little arsenal of used toothbrushes, scotch brite pads, rags, etc.
It is fairly slow and will not replace an industrial machine, but is quite satisfactory for little parts and is able to get into tight little spots and blast the gunk out of there.
Jerry
78 SC hotrod
02 Mini Cooper S
Old 02-23-2005, 07:33 AM
for Oil Flow...look here:
http://www.carcareonline.com/detail.asp?product_id=11002
Wil
Wil Ferch
Old 02-23-2005, 07:55 AM
randywebb's Avatar
corrosive according to the FAA...
Hmmm, the plot thickens. Ben, do you have a web site or anything else on that?
Generally, the best thing to do is to use high-pressure hot water - maybe not pressure washer levels, but 120 psi or so if you've got it. A water heater outlet is useful, or you can install a small on-demand heater somewhere handy.
Next, I would go to an "orange" type cleaner.
Brake cleaner has its own magic...
Just remember, you will be dealing with a mix of polar and non-polar gunk, so you need two types of cleaners.
I know this is anathema to us modern technologically enabled primates, but elbow grease is almost always needed. Brass is the right metal for your cleaning brushes; followed by nylon - avoid steel.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 02-23-2005, 10:02 AM
I hear ya on the age thing, me too--those weren't horse drawn fire trucks were they?
'80 SC
Old 02-23-2005, 11:04 AM
Team California
speeder's Avatar
I have used a lot of different cleaning products over the years to clean greasy parts/motors/etc..., most of the really effective ones were pretty toxic. I'm a big SG user, FWIW, I use it as car wash soap. (Diluted in a lot of H2O). For routine motor/under hood cleaning, I just use GUNK spray "Engine Bright", (NOT the foamy version, it sucks), at the coin car wash. I use it on a fairly hot engine, which makes it more effective, but sometimes it can flame up when it hits the hot exhaust. You have to really be ready w/ the coins to put out the fire.
If you used it the way that the label says, (on cold engine w/ garden hose), I can't imagine how on earth it could work, but they have to cover their asses legally, so there you have it w/ the label. One or two applications @ coin car wash over time has given me fantastic results on my daily driver cars/trucks.
If you want show quality results on aluminum, my advice is to do this: after getting all of the grease and dirt off, use an *etching type* mag wheel cleaner, like Eagle One or Mother's w/ a brass wire brush and scrub the heck out of it, leave the stuff on for a while and then rinse. (This advice is NOT for anodised parts)!!
Here is my case after doing this:
Denis
For the Epsteinth time, the National Guard troops are just a distraction. The only crime wave in DC is the felon in the WH.
Old 02-23-2005, 11:07 AM
I'm also a fan of citrus based cleaners. Home Depot sells gallon containers of the concentrated stuff so you can dilute to taste.
Spray-nine is excellent as well but smells like a stronger version of Fantastic.
Warren & Ron, may you rest in Peace.
Old 02-23-2005, 11:13 AM
