gerard vaglio's Avatar
3.0 into 912?
California changed its smog rules reciently and my 1979sc now has to be smagged every 2 years for the rest of my life. So, I'm starting to look at different options.
Can my 3.0 engine go into a 69 912? How difficult is this, what do I have to do or is it just so much trouble its not worth it. I saw a 912 that I kinda like but need some advice.
Old 01-22-2005, 08:18 PM
A Quiet Boom's Avatar
My 66 912 has a 3.0 in it. The PO installed a 2.0E with carbs, I know it took modifications to do it but I'm not sure what all they entailed. I know you need 911 rear engine mounts and a 911 oil tank, cooler and lines. I removed the 2.0 and intalled the 3.0 with MSD ignition and carbs for simplicity. My car runs the 70-71 911 (901 with late type clutch) trans and it's a total blast. With fiberglass fenders and bumpers it weighs around 2000 with me in it, total go-cart.
Email me about 911 exhaust stud repair tools, rsr911@neo.rr.com
1966 912 converted to 3.0 and IROC body SOLD unfortunately
1986 Ford F350 Crew Cab 7.3 IDI diesel, Banks Sidewinder turbo, ZF5 5spd, 4WD Dana 60 king pin front, DRW, pintle hook and receiver hitch, all steel flat bed with gooseneck hidden hitch. Awesome towing capacity!
Old 01-22-2005, 08:53 PM
Send a message via Yahoo to Lukesportsman
Just about everything short of the VIN will switch over. And that is probably what you'll want to do Drivetrain, spindles, sway bars, torsion bars, shifter, and any aesthetic items or comfort.
Luke S.
72 RS spirit 2.7mfi, 73 3.2 Hotrod on steelies, 76 993 3.3efi TT, 86 trackrat, 91 C4s widebody,02 OLA winning 6GT2, 07 997TT, 72 914 v8,03 900 rwhp 996TT
Old 01-22-2005, 08:58 PM
My 66 911 was rusted so I bought a 912 shell and put the runnung gear in. Then I got a 82 wrecked SC and put the suspension in it. Then i put in a hot 2.7 and the car is real cool. I stripped the motor mount sheet metal off the 911 and just welded it in the corner. No brainer. cot a hole and in goes the oil tank.
Old 01-22-2005, 09:26 PM
inclosed pic
Old 01-22-2005, 09:32 PM
Thanks, you guys are the best. I'll see if the 912 is still available.
Old 01-22-2005, 11:01 PM
