-   -   Got my ducktail - Question on finish (http://forums.pelicanparts.com/porsche-911-technical-forum/202693-got-my-ducktail-question-finish.html)
andrew15 01-21-2005 07:58 PM
I just got my ducktail from MA Shaw - Great guy and fast shipping, but... the finish isn't a smooth gelcoat and looks to have been spray painted with a rattle can in spots?!?
Usually fiberglass is gelcoat finished and smooth, but has to be final prepped by the end user. Does Mike pre-fit / finish the edges and shape and then do a bit of spraying?
Just Wondering,
Andrew M
andrew15 01-21-2005 08:25 PM
Heres a pic of the back where you can see the uneven spraying:
http://forums.pelicanparts.com/uploa...1106367921.jpg
Noel 01-21-2005 08:51 PM
Just curious if the lid has the center section on the underside that is similar to the stock lids. I have A/C and would need this to secure my AC condensor bracket.
andrew15 01-22-2005 05:22 AM
Underside reference picture for you Noel:
http://forums.pelicanparts.com/uploa...1106400134.jpg
efhughes3 01-22-2005 06:46 AM
That looks pretty rough compared to what I got recently from The Racer's Group.http://forums.pelicanparts.com/uploa...1106405179.jpg
Noel 01-22-2005 06:56 AM
Great. thanks. BTW, does the grill opening accept a standard 1974-1989 grill or the smaller early metal grill. The one I got only accepts the smaller grill that I had to buy.
BTW, that finish does look rough to me, but then again, you should fit it onto your car before finishing it, as you may need to sand down some of the sides to make it fit perfectly. Much easier to do before it has been painted. :)
Thanks again.
afterburn 549 01-22-2005 12:25 PM
get out the sanding block(s) and go after it.....then some high build and the usual
1973911s 01-22-2005 12:37 PM
This is what my lid from MA Shaw looked like
http://www.pbase.com/msnowdon/image/27113193/large.jpg
Mike O'Meara 01-22-2005 12:41 PM
The ducktail I bought from MAShaw showed signs of sanding on various edges and some waviness on the outside skin below the tail itself at the spot where on the underside the latch support piece attaches. A little disappointing, but somewhat expected as regards fiberglass. The upper corners will also need work to make them more closely match the body opening contours in order to make the trailing edge of the lid match the body edges at the tail lights.
afterburn 549 01-22-2005 02:40 PM
I have found tha a old magazine all rolled up and taped makes one great sanding block for anything with curves in it..try it you will like it
andrew15 01-22-2005 02:52 PM
1973911s & Mike - Was there any paint on yours when you got it or was it all gelcoat?
Thanks,
Andrew M
paulgtr 01-22-2005 02:59 PM
http://img.photobucket.com/albums/v4.../ducktail1.bmp
http://img.photobucket.com/albums/v4.../ducktail3.bmp
here is my MA Shaw ducktail, it came in raw gelcoat no paint and was very easy to put on. took 1/2 an hour.
as the whole car will be repainted when we do the RS conversion in the spring, I left it in raw form.
Mike O'Meara 01-22-2005 04:07 PM
Mine was just black gel-coated, no paint.
andrew15 01-22-2005 05:22 PM
Thanks guys - I'll call Mike on Monday
Regards,
Andrew M
1973911s 01-22-2005 05:26 PM
No paint on mine, just gel-coat.
Michael
