Bondo and cold weather.
I thought the repairs I did around the top of the rear engine lid where there are water drains would hold up. With the cold weather here my bondo work developed cracks and fell off. I filler the drains for the sunroof with por 15 and usee bondo to smooth everything then painted it too match car. Now the bondo has cracked and actually fell off. Now I need to refill and paint again. How thick can i go with bondo. Also the car never sees rain or snow and is garage kept. I don't want this to happen again.
Old 01-23-2005, 03:33 PM
klaucke's Avatar
Bondo shouldn't be more than 1/8" thick. The thinner the better.
Old 01-23-2005, 03:38 PM
Friend of Warren
Are you applying the bondo to the paint or POR15? If so, that is your problem. Bondo needs to be applied to bare metal.
Kurt V
Old 01-23-2005, 03:43 PM
Air Medal or two
afterburn 549's Avatar
Iam told by my body shop dwn the street that you can go over preped paint.....I have always done it the old way over the bare shiny metal
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between
Old 01-23-2005, 04:02 PM
72 four door's Avatar
Bondo should be applied to scratched bare medal for the best adhesion,Puttys that take out the scratches can be applied over primer,also when your using por-15 you should use the tye coat they suggest.
82 911
70 GTO
97 GT Ragtop
74/76 Jeep cj's
Old 01-23-2005, 05:10 PM
Recreational Mechanic
Nickshu's Avatar
I used a lightweight body filler called Rage, but I didn't go much thicker than 1/8" anywhere. So far no problems. Love to post this pic!
P Cars: 2022 Macan GTS / One empty garage space ---- Other cars: 2019 Golf R 6MT / 2021 F-250 Diesel / 2024 Toyota GR86 6MT ---- Gone: 1997 Spec Boxster Race Car, 2020 GT4, 2004 GT3, 2003 Carrera, 1982 911SC, 2005 Lotus Elise and lots of other non-Porsches
PCA National DE Instructor #202106053 / PCA Club Racing / WRL Endurance Racing
Old 01-23-2005, 06:10 PM
Nickshu's Avatar
pic
Old 01-23-2005, 06:13 PM
