Q
q
Old 01-24-2005, 02:50 PM
david914's Avatar
You trowel on adhesive made for VCT. Believe me, it won't come up unless you REALLY work at it.
David Dryden
'86 911 Coupe
'05 BMW X5 4.4i
Old 01-24-2005, 03:08 PM
Driving member
jester911's Avatar
The floor must be prepped properly. No oil, water, dirt, loose concrete etc. The adhesive is troweled on very thin. You have to wait until the adhesive feels almost dry to the touch, similar to contact cement.
When the adhesive is set up properly and you stick the tile it will not come up.
Jerry
'86 coupe gone but not forgotten
Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason.
Old 01-24-2005, 03:15 PM
84porsche's Avatar
Send a message via Yahoo to 84porsche
The bad part about vinyl tile floors though is that when you drop tools or anything it can dent the tiles. They also scratch very easily. I have placed this type of tile for a company that I used to work for. The surface must be clean and level as these guys have said and you should be fine. Also the adhesive drys fast so once you place it you have a few seconds to move it. If you want to remove it, get a torch and heat the tile to remove. You can remove easily under heat with a trowel.
Modes of Transportation:
1984 Porsche 911 Targa
2003 VW Jetta GLI
Old 01-24-2005, 03:26 PM
david914's Avatar
That's the bad news. The good news is...
Fairly easy and VERY cheap to replace. Don't think you're gonna find that with just about any other finished floor option.
David Dryden
'86 911 Coupe
'05 BMW X5 4.4i
Old 01-24-2005, 03:59 PM
I only had one tile problem, which is right where the right rear tire hits the floor when the lift comes down. I must not have had that spot as spiffy clean (and I'll admit there were a few spots like that ) so when those 315/35 with Kumhos came down de-cambered, and tried to slide over the tile, one side got traction, and caused the tile to subduct it's neighbor and caused a rift in the next one over. That's the only problem I've had with mine. I can live with the little incidental scratches and whatnot.
Old 01-24-2005, 04:33 PM
Automotive Monomaniac
Emission's Avatar
What he says!
Mine are waaaaay stuck to the floor. I jack cars on mine all the time (even the Porsche) and have never seen even a millimeter of movement (of course, I roll the car once it is dropped - no sense pushing my luck).
I have Armstrong VCT (Vinyl Composite Tile) and used Armstrong adhesive. I have a friend who mixed epoxy then put down his VCT - those mothers are stuck forever!
2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order)
Old 01-24-2005, 05:25 PM
Air Medal or two
afterburn 549's Avatar
While were on the topic where is a good place to buy them??
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between
Old 01-24-2005, 05:30 PM
Emission's Avatar
"...Also the adhesive drys fast so once you place it you have a few seconds to move it."
Think contact cement.
You trowel the glue ever so thin... then let it dry (30 minutes or so). Drop a tile... and it sticks.
Like 84porsche says, you can pull tiles up in the future as the glue never really "sets" solid.
Mine have tiny scratches all over them, but it isn't a showroom.
Emission's Avatar
Home Depot.
Armstrong Tile and Glue (and tools too).
Old 01-24-2005, 05:31 PM
Jeff Alton's Avatar
How do these stand up to jackstands and such? Do they seem to wear well?
Jeff
www.turn3autosport.com
Old 01-24-2005, 05:52 PM
Emission's Avatar
Jeff
Anything sharp will permanently dent/chip the tile. They can take a lot of compression (jack wheels or rollers), but not sharp weight (jack stands). I have 12"x12" pieces of wood I put under my jack stands before I lift. Other than that, I don't take any other extreme precautions...
They wear amazingly well. In fact, you can't really see any wear (from abrasion, etc...), just surface scratches that can be buffed out (or waxed over).
My only complaint is that they are a bit slippery when wet, and that some tire compounds will leach chemicals and discolor the light (white) tiles. I just put up with it as the benefits outweigh the drawbacks.
Old 01-24-2005, 06:01 PM
Jeff Alton's Avatar
Great, thanks.
Jeff
Old 01-24-2005, 08:25 PM
Emission's Avatar
Originally posted by SoCal911SC
So the tiles that you bought - did they have sticky on the back of them already, or were they just bare, clean tiles?
The only ones that I found at Home Depot were ones that had peel off backings on them, and some kind of glue on them already. Peel and stick stuff.
Did you use extra glue on those, or what?
You don't want those. You want the kind that are smooth and you need to glue down. Here is what I used:
Armstrong Imperial Texture VCT:
#51910 (black)
#51911 (white)
Armstrong Glue S-750 ~ $13 per gallon (Each gallon covers about 10 feet by 20 feet)
Old 01-25-2005, 11:44 AM
Emission's Avatar
Here, try this. This is an article I wrote for our local Porsche Club re VCT flooring:
http://www.schnellauto.com/reference/vct.pdf
- Mike
Old 01-25-2005, 11:56 AM
Administrator
Jack Olsen's Avatar
VCT looks pretty cheap and easy. However, I have an 80-year-old concrete floor that probably doesn't have a functioning moisture barrier underneath it.
How do the VCT tiles handle moisture? My garage floor is never visibly wet or damp, and I live in the dry Southwest. But I know concrete is porous...
Old 01-25-2005, 01:16 PM
dweymer's Avatar
Jack,
Take a piece of clear plastic(2'x2') like painters tarp about 2-3mil, and tape it down over your floor with duct tape. Let it sit for 36 hours and check for condensation on the inside of the plastic. If there is none, you are good to go.
Donnie
Currently Porsche-less.....
Old 01-25-2005, 01:23 PM
