O2 Sensor Thread Size?
Guys,
Got a SSi Hx that has a oxygen sensor port in it. My 77 C3 engine won't need that hole. Is there a plug for that hole? Does any body know the thread size of an oxygen sensor? Or does anyone have an old dead O2 sensor that they can get me. Thanks |
John,
Try a normal spark plug in the hole. Believe that they are the same size! JoeA |
According to other threads it's 18mm x 1.5mm. It's also been said that a sparkplug should screw into the 02 bung. Shouldn't be hard to find a bolt and wassher to plug.
Hey, with some more spark plug wire and a little richer setting...
I see a flame thrower in my future Thanks! |
Well, back to the drawing board. The hole in the SSi is much larger than a spark plug. Does any one have contact info for SSi?
Thanks |
John, go to the junk yard and get a couple of old O2 sensors off any car (well, most..some have smaller sensors, but they use a bushing). The 18X1.5 is fairly common. You then cut or hammer the sensor and ceramic bit off, then fill it with a weld or JB Weld. Instant plug. If you don't want to go to the trouble of a junk yard, get some cheap O2 sensors from a Farm and Fleet or the sort.
I don't believe that epoxy will hold up at those temps.
Regards, Jerry |
I have 4 old Bosch sensors if that will help.
I'll check the thread and post tomorrow. If it's compatible I'll send it to you. |
Oil pan drain plug (not Porsche). Go to Napa - they'll fix you up.
When someone mentions "sparkplug size"....I hope it's clear that it's not a Porsche (14mm) plug...denoted by a "W" prefix using Bosch nomenclature...but a "D" 18mm plug from some other car....right ??
Wil |
" Is there a plug for that hole? "
I have a note that says a Toyota Truck drain plug has the same thread dimension (M18 x 1.5). Hope this helps, Sherwood http://members.rennlist.org/911pcars |
I ran across this website. Seems like they have what you need:
http://www.belmetric.com/html/catalog16.htm Hope this helps, Sherwood |
Hey Guys,
I went to Standard Auto Parts and got a generic M18 x 1.5 drain plug. It worked like a champ http://forums.pelicanparts.com/uploa...1111950125.jpg Thanks alot! :) |
| All times are GMT -8. The time now is 06:34 PM. |
