Jubbie's Avatar
Question O2 Sensor Thread Size?
Guys,
Got a SSi Hx that has a oxygen sensor port in it. My 77 C3 engine won't need that hole. Is there a plug for that hole? Does any body know the thread size of an oxygen sensor? Or does anyone have an old dead O2 sensor that they can get me.
John F. Lewis
74' 911S Targa + 930/02
76' 914 - Eternal Type IV project FOR SALE
Old 01-25-2005, 02:37 PM
Senior Member
John,
Try a normal spark plug in the hole. Believe that they are the same size!
JoeA
Old 01-25-2005, 02:42 PM
According to other threads it's 18mm x 1.5mm. It's also been said that a sparkplug should screw into the 02 bung. Shouldn't be hard to find a bolt and wassher to plug.
Warren & Ron, may you rest in Peace.
Old 01-25-2005, 02:44 PM
Jubbie's Avatar
Hey, with some more spark plug wire and a little richer setting...
I see a flame thrower in my future
Thanks!
John F. Lewis
Old 01-25-2005, 02:45 PM
ruf-porsche's Avatar
Originally posted by Joeaksa
John,
JoeA
YEP
Old 01-25-2005, 03:35 PM
Jubbie's Avatar
Well, back to the drawing board. The hole in the SSi is much larger than a spark plug. Does any one have contact info for SSi?
John F. Lewis
Old 01-31-2005, 08:26 PM
Somewhere in the Midwest
MotoSook's Avatar
John, go to the junk yard and get a couple of old O2 sensors off any car (well, most..some have smaller sensors, but they use a bushing). The 18X1.5 is fairly common. You then cut or hammer the sensor and ceramic bit off, then fill it with a weld or JB Weld. Instant plug. If you don't want to go to the trouble of a junk yard, get some cheap O2 sensors from a Farm and Fleet or the sort.
Old 01-31-2005, 08:32 PM
SC-targa's Avatar
I don't believe that epoxy will hold up at those temps.
Regards,
Jerry
82 911SC Targa
(05 Boxster S ) gone, but not forgotten
87 Suzuki GSXR-1100
1953 MG TD Mk II
Old 02-01-2005, 05:47 AM
I have 4 old Bosch sensors if that will help.
I'll check the thread and post tomorrow. If it's compatible I'll send it to you.
Old 02-01-2005, 05:53 AM
Mark Wilson
Guest
Posts: n/a
Oil pan drain plug (not Porsche). Go to Napa - they'll fix you up.
Old 02-01-2005, 07:17 AM
When someone mentions "sparkplug size"....I hope it's clear that it's not a Porsche (14mm) plug...denoted by a "W" prefix using Bosch nomenclature...but a "D" 18mm plug from some other car....right ??
Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 02-01-2005, 07:30 AM
" Is there a plug for that hole? "
I have a note that says a Toyota Truck drain plug has the same thread dimension (M18 x 1.5).
Hope this helps,
Sherwood
http://members.rennlist.org/911pcars
Old 02-01-2005, 09:26 AM
I ran across this website. Seems like they have what you need:
http://www.belmetric.com/html/catalog16.htm
Hope this helps,
Sherwood
Old 02-01-2005, 08:17 PM
Jubbie's Avatar
Hey Guys,
I went to Standard Auto Parts and got a generic M18 x 1.5 drain plug. It worked like a champ
Thanks alot!
John F. Lewis
Old 03-27-2005, 11:04 AM
