bagpiper47's Avatar
81 SC Airbox and clutch same time?
Well it's time to go to the Porsche Hospital in Denver. 1981 SC with 86,000. Had a friend tell me Stuttgart does good work and not to much $$. I want to thank Grady for all the info on Independents in Denver.
Wonder if they should do a new clutch while they have the motor out. They said they would measure and if it's 50% + not to worry about it. How much more time would it take? What other things should I consider having done while thay are there?
Old 01-27-2005, 06:56 PM
"Understeer is the sign of the Devil"
1989 911 Carrera Targa (Black)
2001 Jaguar XKR (Silver)
Old 01-29-2005, 05:15 AM
Noel's Avatar
Well, the engine has to come out for bith procedures so the question is do you need a clutch. If it is at 50% and you drive your car 2,000 miles a year then the clutch will last you another ten years. That being said it is still a bit of work once the engine is out.
Gone but not forgotten -
1980 Porsche 911SC w/ -22mm/28mm Torsion Bars | Custom Valved Bilsteins | 22mm/21mm Carrera Sway Bars | Elephant Poly/Bronze Bushings | Carrera Brakes | AJ-USA Brake Cooling | Carrera Oil Cooler w/ Fan | Elephant Strut Brace | Oh, and no ABS or PSM or A/C
Old 01-29-2005, 05:21 AM
JK-81SC's Avatar
Yep, while the engine is out...
Check for any oil leaks. It's much easier to replace leaky o-rings and seals when the engine is out.
I agree that the clutch should last a long time, unless the previous owner didn't know how to drive.
Jeff
1981 911SC Coupe - SSI's + Dansk, MSD, AC delete, Heater Backdate, Euro ride height, polygraphite bushings, Rennshift
1998 F-150 4x4 - Snow Time
1998 Yamaha WR400 - Mountain Ride
Old 01-29-2005, 03:06 PM
