Help identifying CIS electical connectors
Hi all, having had to replace my airbox on my '76 euro Carrera 3.0 (don't ask) I've found there are 2 electrical connectors that could plug in to either the CSV or the back of the fuel distributor?
Both have green connectors on them - can anyone tell me which is which? (one of the connectors has the outer sheath stripped so I may able to identify it through the wire colours inside? - however I don't have a wiring diagram) Thanks! Warren McAllister |
bump
For a USA '76 911S:
Air Meter Switch (air sensor on top of air box near the fuel distributor) has black+brown and brown wires. Cold Start Valve has yellow and red+black wires. |
one is blue, the other is green. they do look similar though. blue to the cold start valve, green to the sensor plate.
Thanks Guys!
Warren |
| All times are GMT -8. The time now is 06:22 AM. |
