Anybody see a problem with this jig?
So we built a wood jig to support the car during the restore and just wanted to make sure that I'm supporting it correctly so when I'm done everything lines up. I know these cars don't bend like 356s but it's good to be safe. Car is a 68 911L. Hard to see but the front is bolted to 4x4 posts that go up to the front suspension mounts. The rear also sits on 4x4 posts bolted to the inside banana arm mounts.
Ken-
Senior Member
Just a thought, you might consider triangulating those vertical 4x4's. Personally, I wouldn't want to put all my trust in those metal brackets alone. It is bolted down right?
I agree with him, I would add some support to the metal brackets. Here is a picture of the support I built for my car when I was transporting it on a rotesserie. Same as yours except it was out of metal and no wheels.
-Britain
'69 912 w/ 2.3L Type-4 Turbo Engine '74 914 1825lbs, JDM Subaru STi Spec-C Engine, Lotus Suspension, 930 Trans. '80 924 AAN 5-Cyl, Corvette C5 Transaxle - Team UBoot Rennwerks -- www.britainracing.com -- |
Ah...yours in San Jose. I am in Milpitas. We should get together sometime and check out each others projects. Mine is a '69.
-Britain
Think of this as a backyard deck. Now think of 10 buddies drinking beer and BBQ burgers. You don't need to put cross braces on this anymore than on your deck.
1987 911 Guards Red Targa, nearing 200,000 miles, lowered, 7's & 8's, 964 grind cams from John Dougherty, A.P.E. Mass Flow Sensor with chip to match, cat bypass, strut brace, dual out muffler. Will consider newer model in 8 years when I turn 75 and then maybe not. 2012 BMW 528i (wife's) 2007 Toyota FJ (rain and off road days) |
decks now require cross-bracing for earthquakes.... that sort of translation and shaking might well happen from somebody pushing or falling against the car's side.
I'd X-brace it but not worry about the metal brackets - the sood itself is providing support vertically Wood is a super strong material in certain directions. I wish we could make a composite like wood out of metal....
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
I'd remove the cardboard box, I think that's kinda overkill
Seriously, though, I would use steel casters, I used small rubber ones like that and they developed flat spots real fast and it was a biosh to get momentum to move the car around. Scott |
Unlike a deck, that dolly has wheels and will be moved around. You'll be introducing lateral loads. Even when stationary, when you work on it you'll sometimes be pushing against it.
Triangulate and don't be sorry!
Chuck Moreland - elephantracing.com - vonnen.com |
Insane Dutchman
This is a frame I used for my last restoration, worked fine rolling it around the garage and also was OK on a flatbed to the bead blaster...this is a pic I took upon its return....
Dennis
1975 911S with Kremer 3.2 1989 911 Carrera Project Car |
This is where a frame machine or jig like a Celette comes into play. Any loads created by bolting down to a perfect surface are good loads. The statement quoted is simply irresponsible. This has absolutely nothing the do with decks or beer and a statement like that comes from nothing but wholesale ignorance. |
Senior Member
Zeke, thanks for saying what I was thinking.
Just add some cross bracing and you'll be fine, David Martin, PE (the state requires me to put that after my name when I make statements like that
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
Even heavy metal straping as shown in Dennis Kalman's photo crossed and lagged to the uprights would provide stability.
Kevin '79 Coupe |
I wouldn't trust it with my life. A.75 inch plywood gusset glued and screwed into the uprights on either end of the fixture. Then add (2) cross ties between the uprights.Again screwed & glued.Dan
I have plenty of lead for my pencil... just not enough paper to write on.. 82SC with 95 993 engine 2004 Ford Powerstroke |
Unconstitutional Patriot
I agree with other posts. Add cross-bracing, and you'll be good. |
Are you going to wet-sign that post?
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
Insane Dutchman
This jig is entirely bolted together, and unfortunately, I sold it a while ago. I built another one for the '79 project that I ended up selling and in a pinch I could ask the buyer to measure it for me....which measurement in particular do you need?
When I built it I actually just did rough measurements off of the car, had the metal place cut everything to length (cost like $1 per cut) and drilled/assembled it as I went. Wasn't too tough to do, took an afternoon to get together. And yes, it is/was strong, stiff and I felt no angst about crawling around underneath it. Only real problem was getting the tub up high enough to get it in underneath. Took some blocking and jacking which was a bit scary... Dennis
Thanks Dennis! I can do the rough measurements, I was just trying to save myself the trip to the garage.
Insane Dutchman
Hey Britian....can you make any comment on the rotisserie that you show in the pictures? I checked out your web site, lot of useful views in there, but I was wondering whether you found any problems with rotating? I'd be worried that it wasn't clost to being balanced and it would be a pain/heavy lifting to rotate it?
Also, I was thinking of using the bumper brackets on my '89, they appear strong enough, but did you have any worries about bending the chassis with teh car supported at both extreme ends, I assume you were crawling around inside of it etc etc.... When I do the math, a 3000 lb Carrera, take off about 700 lbs for engine, 200 for wheels and tires, probably another 200 lbs for suspension, call it 500 lbs for doors, hoods and bumpers, I am guessing that the stripped tub probably weighs in at about 1000lbs or so.....it ought to be strong enough to take it, but does anyone else have any data or thoughts? Dennis Kalma
