efhughes3's Avatar
Cool Dallas PCA dyno day-my results...
One of the guys set up a day on a local Dynojet. I don't have a scanner at home, so I'll have to wait the post the graphs, but here are my runs:
194HP 178.6ft-lbs, 201.4HP 180.4ft-lbs, 202.3HP 182.2ft-lbs
The first (lowest) run was made with my RH tailpipe capped, as I normally do for street driving. Taking it off gave me the extra 8HP. I hope my wife appreciates this sacrifice.
Stock (120K miles) 3.2, B&B headers, Fabspeed muffler, Steve W chip. The chip isn't optimized as it was purchased setup for a Euro pre-muff and sport muffler like I used to have. I'm going to send it back for reprogramming for the headers and 93 octane, so that should help a bit. All in all, I'm pretty pleased...
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 01-29-2005, 12:25 PM
Doesn't want/need a 3.6L
Carrera3.5L's Avatar
Way to go Ed!
Good solid numbers. For comparison, my 3.2L was 199 whp and 182 torque with Dansk pre-muffler, Dansk single in/dual out muffler and Steve Wong chip programmed for the above.
Ralph
P.S. - I guess the 3.4L is now officially "on hold"?
Ralph
1988 Carrera w/ 3.5L Twin-Plug
2008 Cayman S (coming soon)
Old 01-29-2005, 12:48 PM
efhughes3's Avatar
Hey Ralph: Wisdom is most likely going to prevail here, unless I find something bad when I drop it for the clutch, I'm going to do all the "while you're in there" stuff. Now I'll have all that money to spend on suspension of something...
Considering stock should be 207 at the crank, I'm pretty happy with the results here. Easily should be 230 at the crank. If you do the 15% math, it works to 240.
I was holding up on sending my chip to Steve to redo, now I wish I'd done it prior to today.
Ed Hughes
2015 981 Cayman GTS
Old 01-29-2005, 12:54 PM
MBruns for President
JeremyD's Avatar
Good numbers Ed - that's very respectable
Old 01-29-2005, 02:43 PM
Irrationally exuberant
ChrisBennet's Avatar
Re: Dallas PCA dyno day-my results...
Originally posted by efhughes3
the first (lowest) run was made with my RH tailpipe capped, as I normally do for street driving. Taking it off gave me the extra 8HP. I hope my wife appreciates this sacrifice.
LOL!
You can't really compare dyno numbers to factory numbers. The factory numbers were the minimum horsepower.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 01-29-2005, 02:53 PM
