-   -   Bosch H4 Replacement Lens NOT replaceble? (http://forums.pelicanparts.com/porsche-911-technical-forum/203799-bosch-h4-replacement-lens-not-replaceble.html)
plymouthcolt 01-29-2005 06:04 PM
I purchased the Bosch H4 Replacement Lens from Pelican. I tried to install them today but found the old lens is glued on with industrial strength adhesive.
Is there a way to remove the glue, or did I just waste over $50?
jpahemi 01-29-2005 06:14 PM
They're not glued, it's possible the rubber gasket fused to the glass and bezel. Try a little glycerin around the edge of the chrome ring to release the rubber.
J.P.
KTL 01-29-2005 08:06 PM
plymouthcolt,
I see your signature says your car is a 88. Are your headlights the original units from the factory or have they been upgraded to the European H4 assemblies?
If they are the original headlights, then your lenses are H5 lenses. There is a big difference. Take a look @ the bottom, middle of the lens and I think there is the H5 marking above the Bosch logo? The H5 units are indeed those which have lenses permanently affixed to the reflector housing. Translation: if you need a new lens, you must get the entire reflector housing.
If your lights are the European H4 units, then ignore what I said. jpahemi is right on.
For others who are curious, the H5 is on the left and the Euro H4
is on the right.
http://forums.pelicanparts.com/uploa...1068142772.jpg
http://forums.pelicanparts.com/uploa...1068142609.jpg
H4 disassembled
http://forums.pelicanparts.com/uploa...1068143056.jpg
jpahemi 01-29-2005 08:10 PM
Kevin:
Do you have any extra retaining H4 springs for sale?
Regards,
J.P.
KTL 01-29-2005 08:15 PM
Sorry J.P. No spare springs.
The one pictured was takenapart when I bought them, to see how it's put together. So as long as I went through the trouble of disassembly? Figured i'd take a few pictures.
plymouthcolt 01-30-2005 12:15 PM
I couldn't find anything specifally that indicated H4 or H5, so here is a picture.
http://forums.pelicanparts.com/uploa...1107116081.jpg
88-diamondblue 01-30-2005 12:41 PM
plymouthcolt,
That is the H-5 lens. To replace these you need the reflector/lens unit PP #C-631-909-00 I need to do the same on one of my lights.
plymouthcolt 01-30-2005 12:43 PM
Thanks guys.
jester911 01-30-2005 12:46 PM
Not wanting to high jack the thread but are the H-4 lens
and the H-1 lens the same? I need new lenses for my H-1s because they are so pitted.
They look similar.
john walker's workshop 01-30-2005 01:31 PM
the refractor design is different between H1 and H4. i see a lot of them mixed up. the bulbs are in different positions between the two types, so the light doesn't get directed to the right place if the wrong lens is used.
jester911 01-30-2005 01:43 PM
JW. thanks for clarifying that. I did find the lenses here with our host. I just have a hard time paying 40 bucks apiece.
JW, you never cease to amaze me with your wealth of knowledge of these cars.
thanks.
ricochet 01-30-2005 02:04 PM
I also need to improve my H4 reflectors. I pulled mine (am 84 Carrera) with H4 lights. Mine were dull, so I bought the bright blue/white bulbs. I pulled the lights and noticed my H4 reflectors had little reflective material left. The new bulbs had little improvement, the reflector is just near non-reflective. Is that part repaceable? Sorry to hijack the thread, my headlights suck (and my ground is also poor, or non-existant). Can I just replace the reflector? Thanks guys...
Wil Ferch 01-30-2005 03:34 PM
Big hint from the posted pic....
It's an H5 ( as mentioned)...see "DOT" and the aiming "teets" to aim the lens using US equipment that attches to the front face....I'll bet it says H5 somewhere on the lens, too...
Wil
jpahemi 01-30-2005 07:57 PM
ricochet:
The H4 reflectors may still be available; contact Daniel Stern, he has good conections in Germany.
www.danielsternlighting.com
You could also have them replated; I'm in the middle of having a set of H1's done.
Regards,
J.P.
plymouthcolt 01-31-2005 02:37 PM
Can you pass a state inspection with the H-4 since they are not DOT approved?
jpahemi 01-31-2005 05:51 PM
Yes, not to many inspection stations check the DOT lens markings; their're more concerned that they function.
J.P.
JTL 02-01-2005 04:29 AM
Replacement lens source
Upon seeing this post I was trying to think of the place I ordered my h4 and Carrera 84-89 fog lenses. The url is www.foreigncarpartsonline.com They have Bosch h4 lenses ~$30/piece and fogs for ~$29-$42. Go to the site, click on Porshce parts and enter keyword lens. I think that price is rock bottom?
Rgds, JT
-84 targa w fresh repaint
Dan Owens 02-01-2005 06:25 AM
ricochet:
You can have your old reflectors re-chromed and they turn out great. I had mine done about 2 months ago and they are excellent, I was shocked at the quality. I sent them to:
Ideal Custom Plating
937 S 6th Ave Tucson 85701
Toll Free 1-888-878-9090
It cost me $95 for both plus shipping and took about 3 weeks. A little slower than I'd have liked but it was worth it and about 1/2 the price of anywhere else I could find.
allaircooled 02-01-2005 06:29 AM
How many do you need? I have a couple at home (I believe) that I will give you.
Chris
alan911sc 02-01-2005 06:38 AM
Might have some H4 reflectors in my garage attic if someone needs them. Lenses were broke during a wreck. But I kinda remember the reflectors being OK.
RickM 02-01-2005 06:39 AM
This place is being used for replating by some of the folks over at the MercedesShop SL forum: Steve's Auto Restorations @ 503-665-2222
Waiting on the end result. I'll keep all posted.
$75 to refinish two glass reflectors.
plymouthcolt 02-01-2005 02:05 PM
Alan, I will take those off your hands. I bought H4 lens not realizing I had h5.
ricochet 02-01-2005 04:27 PM
Thanks for all the great info, and I apologize for feeding off yer thread plymouthcolt. I learned a lot here again. Woulda probably taken them Alan, but was beat to the draw.
hgray 02-01-2005 10:02 PM
I am pretty sure that any electro plating shop would be able to re-chrome a set of reflectors..... try calling around from the Yellow Pages in your area.
Wil Ferch 02-02-2005 08:04 AM
Plymoutcolt...
If you convert to H4 from your present H5...you do understand that the plug / receptacle won't fit your car....right? Mods necessary here... :(
...but worthwhile to do !
Wil
