billyboy's Avatar
noticed some rust
I was poking around the front pan and found some thin spots. So a couple of hours with the plasma arc and grinder... Welding starts tomorrow
'68 911 2.2 "E" PMO Carbs, Electromotive Crankfire Ignition, Adjustable Spring Plates, turbo tie rods, Bilsteins, headers, MB911 muffler...
"The sea merely lies in wait for the innocent but it stalks the unwary."
Old 01-29-2005, 09:15 PM
Zeke's Avatar
Here's a tip: Make sure your front suspension pieces bolt up right before you finish. I didn't and I got a big surprise when everything was laid out and ready to assemble. These repro parts are not perfect by any means, which you will discover in due time. The alignment is OK, but the holes were too far apart for the bolts to go in w/o widening the elongated slots in the mounting bracket. No big deal, I guess, but filing and grinding on fresh powder coated pieces kinda defeats the purpose of the powder coat.
Do a trial assembly after tacking everything up and find any problems then.
Old 01-29-2005, 10:01 PM
billyboy's Avatar
aftermarket pieces
I have already found that the threads in the new piece are too tight to get a bolt started. I am going to run a tap through them all before I do any welding. I'm hoping that it's just the paint in there.I plan on bolting up the front of the "a" arm prior to any tacking so i may discover the need to do some more grinding.
Old 01-30-2005, 07:41 AM
Not Quite Banned
Thomas Owen's Avatar
Very nice job so far. Post the finished results if you don't mind.
Thomas Owen
1972 911T
1972 911S
Old 01-30-2005, 08:24 AM
billyboy's Avatar
pan in
I've got the pan all welded in. Now I am trying to position the other piece that goes on top of it. I think it's called the gas tank support. From other threads and pictures, it looks like the rear edge of that piece sits about 1/2" forward on the edge of the lip of the gas tank hole in the pan piece.It is not flush, correct?I know this is kinda wordy. Zeke? Shuie?
Old 02-12-2005, 08:04 AM
Licensed User
Shuie's Avatar
Looks good! Nice work!
Clean the crud from the old seal off of the tank and do a test fit with it. The panels that I had for my '73 lined up very well. I sold my car before I welded the tank support in and I never took that measurement. Sorry I cant help more than that
Old 02-12-2005, 08:08 AM
Tim K's Avatar
Here is what mine looked like.
I used the Restoration Design front tank support. I thought the fit was very good, although it required some minor tweeking at both ends where they contact the left and right tank supports.
I fiddled around for a while trying to get it in the exact same place as the original, but in the end it was best to adjust to the best fit and, as Shuie mentioned, check with the tank in place.
Good luck!
Tim K
Old 02-12-2005, 10:08 AM
Automotive Monomaniac
Emission's Avatar
Oh, to have a plasma arc just sitting around....
2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order)
Old 02-12-2005, 10:12 AM
You guys have some valuable skills.
Nice looking work.
Regards,
Markus
Old 02-12-2005, 01:08 PM
billyboy's Avatar
gas tank support in
Just finished welding in the gas tank support. It took a little bit of tweeking to get it in right. The piece looked like it had been messed with before, maybe someone drove a forklift over it at the factory.
Old 02-13-2005, 07:11 PM
