Natog's Avatar
Brake pads for 87 Turbo Look
I am about to order some brake pads for my 1987 factory turbo look.
I have the the ones for the turbo on my project list, wanted to make sure that is what I needed:
http://www.pelicanparts.com/catalog/shopcart/911M/POR_911M_brakes_pg6.htm#item22
Fronts:
OEM Front Brake Pad Set, 911 Turbo (1978-89)
M-351-939-03 $68.25
Rears:
OEM Rear Brake Pad Set, 911 Turbo (1978-89)
M-351-939-03R $68.25
My rotors are fine, I just want to replace the pads. Normal street use, perhaps one track day a year.
Also, should I replace the sensors?
(BTW I did email Pelican, but my questions were not answered and instead I was directed to get new rotors as well, so I wanted to ask here).
Old 02-01-2005, 12:56 PM
Bill Verburg's Avatar
Yes, those pads are the ones you want. Don't bother replacing sensors.
Bill Verburg
Old 02-01-2005, 01:08 PM
Natog's Avatar
Thanks Bill, much appreciated.
Old 02-01-2005, 01:47 PM
MBruns for President
JeremyD's Avatar
There is usually a minum spec printed on the outside of the rotor - just make sure you are higher than the minum spec and you don't have to replace the rotors. Not sure what those are - but Bill probably has those on the top of his head...
Old 02-01-2005, 01:49 PM
