-   -   Wheel spacers effect on handling (http://forums.pelicanparts.com/porsche-911-technical-forum/204347-wheel-spacers-effect-handling.html)
doozer 02-02-2005 12:14 PM
Does spacing out the front wheels (using spacers) have a negative effect on handling??
Chuck Moreland 02-02-2005 12:25 PM
Front spacers reduce the wheel rate by effectively lengthening the control arm.
They increase the scrub radius, making steering effort a bit heavier.
They widen the track.
They change the ackerman angle.
These are not necessarily negatives.
doozer 02-02-2005 12:27 PM
As always, Thanks Chuck!
Miguel Antonett 02-02-2005 12:49 PM
Also, by lenghtening the control arm effect you increase the negative camber generating more inside wear on your front tires. I would say that handling gets better.
Chuck Moreland 02-02-2005 01:01 PM
Actually spacers do not effect camber because they are on the outboard side of the strut. acheiving increased camber requires lengthening the control arm inboard of the strut.
doozer 02-02-2005 01:19 PM
Correct, no change in camber at the centerline, but the travel of the leading edge of the wheel/tire will be greater.
stlrj 02-02-2005 02:28 PM
Moving the front wheels out adds stress to the outer wheel bearings which are smaller and weaker compared to larger inner bearings which could cause them to fail prematurely.
Cheers,
Joe
