Ray 911s's Avatar
A-Arms
I have a pair of A-arms in the garage that I'm thinking about refinishing for my 77. Before I do so, however, I need to know exactly which years they fit. Usually that is easy enough - but I don't see any part numbers on these.
Can anybody tell me where to look for part numbers, or how to tell which years they fit? What are the identifying features/marks I should look for?
1977 911S
1973 Alfa Romeo GT Veloce
1997 Lotus Turbo Esprit V8
2016 AMG C63S
Old 02-05-2005, 01:49 PM
randywebb's Avatar
look at the ball joints & the distance between holes for the caliper mounts. search those terms for the years/models where they differ
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 02-05-2005, 02:57 PM
Ray 911s's Avatar
Thanks Randy. I'm not asking about struts, though. I need similar details on the a-arms.
1977 911S
2016 AMG C63S
Old 02-05-2005, 05:04 PM
PMB Performance
Eric_Shea's Avatar
Any a-arm should fit a 77 no? You'll want updated ball joints as Randy discussed but if you have a 77 and you have a-arms in the garage, you should have something that will bolt on.
Eric Shea - PMB Performance
855-STOP-101
We Restore Vintage Calipers
www.pmbperformance.com
Old 02-05-2005, 05:13 PM
Chuck Moreland's Avatar
Those arms are correct for all cars 74-89. They can be used on cars 69-73, though they need to have the early style sway bar mounts welded on. They can also be used on 68, but require late style ball joints in addition to the sway bar mounts. They can also be used on cars 65-67, but will need to use a later style crossmember, in addition to ball joints, and in addition to the sway bar mod.
Chuck Moreland - elephantracing.com - vonnen.com
Old 02-05-2005, 05:16 PM
Ray 911s's Avatar
Thanks team. I went out to get new batteries for the digital.
So if I read correctly, these will fit 74 to 89, but also have tabs to fit 69 to 73?
1977 911S
2016 AMG C63S
Old 02-05-2005, 05:31 PM
PMB Performance
Eric_Shea's Avatar
I don't think we know what year the arms are... we know they're going on a 77 though.
855-STOP-101
Old 02-05-2005, 05:32 PM
PMB Performance
Eric_Shea's Avatar
Now we know they're pre 74
Those should bolt right on. No problem. Do you have a through body sway bar upgrade on the 77?
855-STOP-101
Old 02-05-2005, 05:33 PM
Those arms are 69-73 variety. They have the early style sway bar mounts.
If you convert your 77 to through-body sway bar, you are all set. If you keep the original, you'll need to change out those mounts.
Better yet, find someone who wants to swap you.
Old 02-05-2005, 05:34 PM
PMB Performance
Eric_Shea's Avatar
I'd convert to a through body bar at this time... better geometry and more options.
855-STOP-101
Old 02-05-2005, 05:37 PM
Ray 911s's Avatar
Excellent. Thanks for the help. I'll crawl under the car with a light and see what else is up there. Honestly I don't know what sway set-up it has. The front end is a little close to the ground right now - I'm installing the engine and have the back up in the air.
Thanks again for the help, though. I'll take the through-body under advisement.
1977 911S
2016 AMG C63S
Old 02-05-2005, 05:42 PM
I had a stock 74 and my stock 77 both have those exact a-arms so what are the odds that they back dated both of my cars a-arms ???
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 02-05-2005, 05:49 PM
PMB Performance
Eric_Shea's Avatar
Ben,
The odds are pretty good based on Porsche switching to underbody sway-bars in 1974. The 1976 930 (76 only) still had a through body bar and it was 18mm. Nice bar for early cars if you can find them. Many people welded on the u-tabs and converted back to through body as those were the only bars that offered upgrades at the time. 74-77 probably came with 18mm under-body bars.
I have a spare 20mm under-body bar if anyone wants it cheeeeeap.
855-STOP-101
Old 02-05-2005, 07:14 PM
randywebb's Avatar
Hey Ray - would you like to put those on a scale at UPS and report the weight?
Old 02-05-2005, 08:06 PM
