Alii&Maui
Jesset100's Avatar
Heated air path
After the hot air goes thru flapper box what path does the heated air take? Does the heater ducts go in the shifter rod tunnel or does it take a path that goes near the rocker panel?
Heat Exchanger>Flapper Boxes>Heater Ducts(?where?)>Enter Behind Dash(?Where?)>Dash Vent
Is there a body diagram showing me what i'm looking for somewhere?
1982 SC Coupe
SCWDP#0087
KCSSL#0082
Old 02-05-2005, 09:22 PM
They go thru the rockers...
...can't remember where, but one form of factory dwg shows this pathway...
Try tech articles from Panorama...maybe by Allen Caldwell.....
Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 02-06-2005, 02:25 PM
SteveM911's Avatar
They go through the tubes built into the rockers and then join flexible hoses behind the kick panels to the side of drivers left foot and to the side of the passengers right foot.
Steve (Strosek34)
86 - Carrera 3.4 LWT
www.impactbumpers.com
Old 02-07-2005, 01:35 AM
Used Up User
imcarthur's Avatar
I got this from somewhere on the net. In an article titled "Early 900 Heating Systems"
Ian
'87 Carrera Cab
Old 02-07-2005, 08:20 AM
Alii&Maui
Jesset100's Avatar
Thank you fellas! This is going to help alot.
1982 SC Coupe
SCWDP#0087
KCSSL#0082
Old 02-07-2005, 06:57 PM
I was looking for this info also. As Wil said above I found this picture and an article in the Feb 2001 Panorama. Thanks.
Old 02-07-2005, 09:05 PM
That's the one !!!! ......
Wil
Wil Ferch
Old 02-08-2005, 06:19 AM
Jesse, you already knew the answer to your question. Now admit it, you wanted to show off your new heater box, didnt you? My heater boxes are the ugliest part of my car. I am scared to pull the lever up because they will probably fall apart from the rust.
Old 02-08-2005, 06:23 AM
Jerome Ryals's Avatar
These pics may help some.
First is by the passenger side footwell, second is from inside trunk on passenger side and last is the passenger side rear. Cutting a tub up and thought pics might help.
Old 02-08-2005, 02:22 PM
Alii&Maui
Jesset100's Avatar
Jerome Ryals> Big help Thanks!
DrewT> The truth be told. The picture is from a Pelican tech article.
This is my situation. My heat exchangers were rusted thru so I broke out the dremel and cut the "outer shell" off. That stuff is tuff! I think it's aluminum (sp) and stainless steel. Anyway, what I have left is what looks like headers. I'm trying to figure out how I can get heat in the cabin without buying SSI's, backdate, bla, bla, bla.
I was thinking that if I knew where the path the air took I could maybe "tap" into it and pull heated air around the flapper boxes. Or use the fresh air blower to "draw" heated air in. I don't need alot of hot air just some
Any suggestions?
1982 SC Coupe
SCWDP#0087
KCSSL#0082
Old 02-08-2005, 09:44 PM
