-   -   Animated 911 engine, enhanced (http://forums.pelicanparts.com/porsche-911-technical-forum/204904-animated-911-engine-enhanced.html)
DonNewton 02-06-2005 10:49 PM
DOH! Got it to work. You really do have to 10% smarter than the equipment!
chrisp 02-07-2005 06:31 AM
this is great. My wife has been asking how an engine works for months. Without a good illustration I couldn't show her. We'll use this one, it's perfect.
thanks!
svandamme 02-07-2005 07:03 AM
sweeeet
mfi version , can't wait... the bigger res the better !!
911S Targa 02-07-2005 08:29 AM
I have mine animated as my desktop wallpaper.
Thanks !!!!
adamred 02-07-2005 09:40 AM
awesome! now let's see one where you miss a downshift and peg 10,000 RPMs
svandamme 02-07-2005 09:46 AM
easy
overclock pc
boot pc
launch animation
just like on a real overrev... you should see smoke fairly soon
Blanco 02-07-2005 10:18 AM
:eek: Awesome...
Jamie79SC 02-07-2005 10:19 AM
Too cool. Is it a trick of my PC or is the pully on the fan turning the wrong way?
sixbanger 02-07-2005 11:09 AM
Did anyone bother to check the oil?
FranksPlace2 02-07-2005 01:25 PM
"Too cool. Is it a trick of my PC or is the pully on the fan turning the wrong way?
Jamie79SC"
The crank and the fan are both clearly going cw but fan pulley looks like it is ccw. I think it is synchronous so the next image looks like the one before the present image.
Frank
Dennis Kalma 02-07-2005 01:28 PM
I love it, just keep on wishing for more....how about a flash of white/orange in the cylinder when the spark plug fires, with dull red exhaust exiting the cylinder...
Oh and I'd love colour in the engine...nice aluminium shades to separate actual engine from space and oh....
I suppose there is no end to things that could be added.....it is on my desktop now and I think it is great as it is.................
Dennis
Grady Clay 02-07-2005 01:33 PM
Darryl,
If you want any technical advice on MFI, cam timing or anything feel free to e-mail me. There are some MFI diagrams I can scan for you. I have some other cool ideas for you.
Best,
Grady
gradyclay@hotmail.com
masraum 02-07-2005 01:34 PM
To set the gif as you background, but keep it animated instead of selecting "set as background" when you right click choose "set as desktop item".
A desktop item is using active desktop instead of setting it as desktop wallpaper. You should probably first right click and "save as" to your computer somewhere. Then click programs, control panel, display. Once the display box comes up click "desktop" then "customize desktop" then when the next box comes up click "web". Once in Web click "Add" then browse to the image on your computer and select it.
Once the image is on your desktop you can move it around by dragging the top thicker border (border appears when you put the mouse over the image). You can also click the first box from the left in the top border to maximize the image on your desktop. It is also possible to resize the image by dragging the sides or corners of the image.
This method also works well for adding regular jpg images to your desktop because it uses less memory than the usual "set as background"
Also, I used to use an animate gif as my desktop, but I noticed that it was bumping my cpu utilization up by 10-15%, so I stopped. The impact you feel will be determined by the image and your PC, so it may not be an issue for you.
masraum 02-07-2005 01:37 PM
Ever notice how the wheels on Semi-trucks on the freeway sometimes look like they are spinning backwards? Has to do with the frequency of the spinning and the locations of the holes and how our eyes see or something like that, I think.
Bill Verburg 02-07-2005 02:40 PM
If I could get my hands on a later EFI engine factory manual, an animation of that could be possible too. I just need a nice detailed cut-away drawing as a starting point.
Something like this?
993RS
http://forums.pelicanparts.com/uploa...1107815967.jpg
widebody911 02-07-2005 04:58 PM
How about a 4-cam carrera, or a 917 (912) engine? :)
Or maybe you could show the path of an errant washer that gets sucked into the engine!
What are you using it to animate it? I have similar images of VW engines.
DarrylD 02-07-2005 10:39 PM
I just made yet another addition to the model, the connecting rods are now complete, there's a nut to retain the bolt!
http://members.aol.com/darryld/930.gif
Grady, I'll take you up on that MFI modeling technical assistance!
Bill! Yes, that's exactly the type of drawing I seek for an EFI project!
What tools to I use to do these animations? Microsoft Windows Paint and Microsoft Picture-it 9.0 to build the "flip-book" and rotate pieces by 1º increments. Most of the work I do at the pixel level using 6x magnification of a 1000x792 sized drawing.
It's like electronic knitting... it relaxes me. :eek:
DonNewton 02-07-2005 11:28 PM
Wow!
Argeo 02-08-2005 06:09 AM
Man, I hate being computer illiterate. I have the image but no movement. Running XP. Ughh!
This thing is great. Thanks.
Dennis Kalma 02-08-2005 07:23 AM
As one other lister suggested, what a wonderful way to teach the operation of a gasoline engine...
All we need is the sound effects.....you know.....Suck -Squeeze - Pop - Phooey....
Love it...
Dennis
