-   -   Check out my "smuggler's box" 10-disc CD player rack (http://forums.pelicanparts.com/porsche-911-technical-forum/205261-check-out-my-smugglers-box-10-disc-cd-player-rack.html)
DarrylD 02-07-2005 06:36 PM
Enough playing with animating engines, how about some sheetmetal fabrication for today's actiivity!
Check out the rack I fabricated to hold my 10-disk CD changer in that wasted space called the "smuggler's box:"
http://members.aol.com/darryld/10cdrack.jpg
The idea is to suspend the deck in the opening of the "smuggler's box" lid depression.
The "bezel" (the part shaped like the lid of the "smuggler's box" is made of 14-gauge steel, the box is 22-gauge. 14-gauge should be stout enough to bear the weight of the deck without flexing when the road gets rough.
The box in the rack will be water-tight and the seal around the "smuggler's box" lid will seal it from dust. I'll add some adheasive foam weatherstrip to the bottom edge of the "bezel" of the rack to seal dust and moisture out of the trunk.
All that is required to remove the rack to get at the steering linkage is lift it out and unplug the CD deck. The latch of the lid will hold the rack in place when it's closed.
DarrylD 02-07-2005 06:42 PM
Here's the front view, prepped for paint...
http://members.aol.com/darryld/cdrack2.jpg
A coat of semi-gloss black paint is drying on it as I type...
doozer 02-07-2005 06:54 PM
Looks Awsome!!!
Good job!
azasadny 02-07-2005 07:46 PM
Darryl,
How much? I'd love to put one of those in my '74 but I'm not nearly as talented as you! Great work! My CD changer is a Pioneer and is probably the same size as your Kenwood. I'm serious, I'd buy one if you sold them!
al lkosmal 02-07-2005 07:56 PM
Darryl,
That looks nice and functional. Good job.
Al
1987CarreraKid 02-07-2005 08:49 PM
looks great, i cant wait to see the finished product.
bigrubberjeep 02-07-2005 09:52 PM
Looks great, actually fantastic.
But.........you could just buy a cd player that plays MP3's and burn a single disk that could hold as many songs as the heavy cd changer with 10 cd's in it.
I know, technology suck$.
DarrylD 02-07-2005 10:47 PM
Holy cow Art! You think I have the skills to make two exactly the same? My metalworking skills are "organic" and the design evolves as I put it together!
I appreciate the positive feedback!
Ok, did I forget to mention my 911 came with the 10-disk deck and in-dash controller? Oh, yeah, and my 20-year collection of CDs that are already paid for? The total cost of the sheetmetal was $13.
MAS 02-08-2005 01:31 AM
Nice work. My amp is in my smuggler's box. But it's mounted on a diagonal board.
-MAS
bigrubberjeep 02-08-2005 10:00 AM
You could make a compilation of all your favorites in to one.
Just a thought.
doozer 02-08-2005 10:05 AM
Make a box to hold one of these and you could have all the MP3's you would ever want! ( on 80gb hard drive!)
Hmmm... also email and internet..... $500 :D
http://images.apple.com/macmini/imag...op20050111.jpg
http://images.apple.com/macmini/imag...ns20050111.jpg
http://images.apple.com/macmini/imag...ts20050111.jpg
Craig 930 RS 02-08-2005 11:20 AM
Really well done!
Makes more sense - IMO - than putting a battery in there and moving the weight distribution further backwards......
Az911 02-08-2005 11:25 AM
Good job I like it
js1099 02-08-2005 11:54 AM
Would somebody mind telling this newbie where the smuggler's box is and how to open it. Thanks in advance.
Rich76_911s 02-08-2005 12:02 PM
The smugglers box is in the front trunk. To find it simply pull up the carpet, and to your surpise there will be a little door on the passengers side near where the cars black plastic stamped serial numbers are. When you look inside it hopefully you don't find mice, I did, what you should see is part of the steering mechanism.
Moses 02-08-2005 12:06 PM
Re: Check out my "smuggler's box" 10-disc CD player rack
Great work, but where do you put your weed now?
DarrylD 02-08-2005 12:08 PM
Ok, it's done and installed this morning!
I painted the entire box semi-gloss black, silicone caulked all the seams and then painted the "bezel" with black "wrinkle" paint like that used on electronic component cases.
http://members.aol.com/darryld/rackdone.jpg
The threaded mounting bracket holes in the CD-player line up with the holes in the rack so I "bolted" it in to place, hooked-up the 12-pin plug through the case and sealed it with 3M strip caulk (aka "monkey *****" in the industry) so it's water-tight from the bottom. I also put foam adhesive weatherstrip around the underside of the "bezel" to seal the trunk from dust and moisture.
I thought the "wrinkle" paint looked more industrial and wouldn't show fingerprints or scratches like the semi-gloss paint would.
You like?
js1099 02-08-2005 12:08 PM
Thanks Rich, I will go look for weed in it tonight!
Bobboloo 02-08-2005 12:10 PM
That's the idea. You think Apple did well with the Ipod. How about run your music, internet, GPS, DVD's and if you were so inclined you could run different maps for your EFI. One for street. One for the track.
"On your mark, get set, go."
doozer 02-08-2005 12:13 PM
Re: Re: Check out my "smuggler's box" 10-disc CD player rack
He is having his weed pressed into discs, Disk 7-10, find that copper! :D :D :D
